08-09-2013, 05:42 PM | #1 |
Pick my cam!!!!!!!!
83 lwb 355 2wd 700r4 2200 stall converter.
i had this lunati voodoo cam and wiped a lobe and lifter so.... •Advertised Duration (Int/Exh): 268/276 •Duration @ .050 (Int/Exh): 227/233 •Gross Valve Lift (Int/Exh): .489/.504 •LSA/ICL: 110/106 •Valve Lash (Int/Exh): Hyd/Hyd •RPM Range: 1800-6200 i want something to get my big heavy truck up and moving. i dont race or intend to, and stock sucks. i like a nice aggressive idle.... i dont have power brakes....or a/c, and i like performance. i have a dual plane intake and a edelbrock carb..... 1....2.....3.......GO!
*^MY BUILD STORY^* |
08-09-2013, 06:39 PM | #2 |
Re: Pick my cam!!!!!!!!
comp cam 280 magnum great cam in a 355!!!
08-09-2013, 06:51 PM | #3 |
i would go one step up in the voodoo line!
"DON'T TOUCH THE TRIM!!"-Early Kyler |
08-09-2013, 07:58 PM | #4 |
Are you posting the specs of the cam you have, or the one you are thinking of?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
08-09-2013, 08:43 PM | #5 | |
08-09-2013, 09:09 PM | #6 |
What's your setup on your current motor for carb intake exhaust heads and such? That cam should be good for close to 400hp with a good combo motor . Now that you've wiped a lobe or two your bearings are also trashed in the motor and oil pump as well. Wouldn't be a bad idea to re ring and bearing the motor for good measure.
Also run zinc additive from now on. Keep that from happening again Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
08-09-2013, 09:25 PM | #7 |
The thumper cam was still bigger than the 268 cam from lunati
You need some 3:73 gears and a 3000 stall converter and I hope that 700r4 is built tough 1.6 ratio rockers will add more duration as they lift. From what I saw in your build thread the air gap is a good intake. The heads look like later lt1 heads I think. What's the compression of the engine? You need about 9.5:1 before any cam will start magic. Somone is bound to tell you this but...vortec heads. Really a great way to add another 50hp Look up bullet cams and fill out their recommendation sheet honestly and they can get you a nice ultradyne cam grind that will max out your combo Posted via Mobile Device
08-10-2013, 12:42 AM | #8 |
Wow! Thanks for the responses guys! I think I am just going to put in my comp thumpr cam (12-600-4) in since its just laying around... Also thinking of maybe putting some roller rockers on? Is that a good idea?
08-10-2013, 12:45 AM | #9 |
have fun building a slug!
08-10-2013, 02:28 AM | #10 |
Meatwagon are you saying how the thumper is a bad cam? Please explain your cam experience with thumprs
1.6 rockers are good make sure your valve springs can handle the lift and duration. Make sure you have at least a 2500 stall for this cam. It's designed after a few circle track cams so the torque hits hard about then and peaks around 6k. Not a drag cam but great on corners and the street. Keeps my vacuum for brakes and drives happy as a clam on the street and plenty of power when your on it. Not a slug by any means at low rpm still wastes tge tires easily even at a roll. but def stronger past 2500. I will see about throwing up a vid. Posted via Mobile Device
08-10-2013, 09:14 AM | #11 |
I have valve springs good door 550 lift so I'm good there. My stall should converter should be fine.
08-10-2013, 09:23 AM | #12 |
I agree...........that Comp 280 H Cam is Awesome.. nice lump..
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
08-10-2013, 10:05 AM | #13 |
08-10-2013, 11:07 AM | #14 | |
btw you are the only person i have heard have good things to say about a thumpr cam, but unlike others uninformed opinion mine is informed!
08-10-2013, 01:46 PM | #15 |
Really a bigger cam with more lift and duration runs stronger?
I have 1.6 1.52 staggered rockers on my engine. Not to be rude or anything but maybe your engine combo just sucke for that cam? The magnum cams have a slower profile on the lobes which is why they are better at torque. The thumpr has the xe profile. Both magnum and xe have profiles I don't like. But for a daily driver engine the cam works great. Not a race engine and sure I can get 10-15 more hp/tq from another grind but it won't do what this one can Posted via Mobile Device
08-10-2013, 02:17 PM | #16 | |
I know the pieces fit
08-10-2013, 06:00 PM | #17 |
[QUOTE=northeimcustom;6212865]83 lwb 355 2wd 700r4 2200 stall converter.
i had this lunati voodoo cam and wiped a lobe and lifter so.... •Advertised Duration (Int/Exh): 268/276 •Duration @ .050 (Int/Exh): 227/233 •Gross Valve Lift (Int/Exh): .489/.504 •LSA/ICL: 110/106 •Valve Lash (Int/Exh): Hyd/Hyd •RPM Range: 1800-6200 This is still a pretty stout cam for the street. My money is your gearing is bad and the edelbrock is killing it. And if the engine doesn't have flat tops then prob low on compression Posted via Mobile Device
08-11-2013, 01:02 AM | #18 | |
08-11-2013, 04:12 AM | #19 |
Yah I didn't like the big block numbers. An I put the rockers in cause I knew that would fix the cam to where it needed to be. Just the small thumpr looked good to me the others were odd.
08-12-2013, 10:24 AM | #20 | |
also i am looking for something that would give me a little more low end torque, but that maybe be just my gears at this point...
08-12-2013, 10:26 AM | #21 | |
[quote=INSIDIOUS '86;6214316]
no idea what i have for gears, but i have been meaning to check them out. whats wrong with the edelbrock you think?
08-12-2013, 11:38 AM | #22 |
That cam is pretty healthy and should be matched to the rear gears and torque converter to run right. I wouldn't fault the cam or cam mfg for the failure, oil isn't what it used to be and will kill a flat tappet cam without additives.
08-12-2013, 11:59 AM | #23 |
i have a voodoo in my chevelle and that thing is a friggin brute!! but it is a pretty healthy camshaft
08-12-2013, 12:01 PM | #24 | |
good to know, i am definately going to run some additives from now on! what will give me the most benifits all 1.6 rockers or just exhaust or just intake? dont know anything about off setting them.....
