Old 08-11-2013, 09:18 PM   #1
MailManX2
MailManX2's Avatar
Bought a tailgate a couple weeks ago.....
Could hear something sliding back and forth inside so I decided to investigate
Not too scary looking
Not too scary looking here either
Rust holes made by my thumb when picking it up.. Not a good sign
Ugh.. why me... The rust pile on the left is 2" + high.
I'm wondering if it'll survive abrasive blasting..
Ken B
60 Chevy Apache
2019 Chevy Silverado Z71
Why buy something when you can build it for twice the price..
Just because something can be done doesn't mean it should be done...
MailManX2 is offline   Reply With Quote
Old 08-11-2013, 09:34 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Bought a tailgate a couple weeks ago.....
Aw common a little brake work with some sheet metal. You were going to have to weld the side piece back on anyways!
Old 08-11-2013, 10:18 PM   #3
donthekawguy
donthekawguy's Avatar
If anything it will be a cool piece of wall art.
66 shorty
donthekawguy is offline   Reply With Quote
Old 08-12-2013, 09:48 AM   #4
chevyrestoguy
chevyrestoguy's Avatar
Your situation is not that uncommon. Water likes to rest in the area where the trunions are, and rust will eventually form because it has nowhere to drain. I bought a cherry tailgate down in L.A. a few years back, and although it was solid and rust-free on the exterior, both of the trunions was rusted and frozen up. I Had to soak one of the ends in Kroil for a few days, and after a bit of work, it got it free. The other side would not budge, so I had to get a long (4') pipe and slide it into the bottom of the tailgate and drive the frozen trunion out.
Your picture of your rust pile looks exactly like what I got out of mine!! It was a lot.
Do everything you can to save your existing tailgate. The aftermarket tailgates are nowhere close to the thickness and quality of a factory original piece.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-12-2013, 12:21 PM   #5
ljackson
ljackson's Avatar
You might want to get a different one. Make a bench with this one. Cool examples here. http://www.bing.com/images/search?q=...ch&FORM=HDRSC2
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 08-12-2013, 08:50 PM   #6
MailManX2
MailManX2's Avatar
I'll fix it, just need some 16 gauge sheet-metal and a length of pipe that's the correct diameter to wrap the sheet-metal around. Heck, after replacing the roof, cowl, floor, cab corners, rocker panels, etc. this should be easy..
Ken B
60 Chevy Apache
