![]() Join Date: Nov 2011
Vacuum line for brake booster
Hey guys I'm trying to figure out where my hose out of my brake booster needs to get vacuum from. I have a holley carb and a edelbrock manifold. Thank you very much
Posted via Mobile Device |
Re: Vacuum line for brake booster
On your Edelbrock manifold there should be a threaded port with a plug in it located between the back of the carbs base and the Distributor. That's were you'd typically get your vacuum for your booster and also use a "T" fitting to go to your vacuum modulator with a Turbo 350-400 trans if you have one.
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
Ok great so I can use that port I also heard of guys putting on a carb spacer and tapping a fitting for vacuum. I just wasn't sure of that thanks for the feedback
My Holley has a port in the back that feeds the brake booster. Could keep you from having to outfit with a fitting, etc..
