Old 08-13-2013, 12:07 PM   #1
DURG
DURG's Avatar
Re: Changing rear end angle.
Right - MOST Chevy intakes will set your carb level with the engine down 3 to 3.5 degrees at the rear.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 08-14-2013, 03:50 PM   #2
wayno
In doing some more research it looks like you are all correct calling for 3" down on transmission - at 5" ride height measured at the frame by the rear cab mount- I thought I had read somewhere that the pumpkin in the rear should be on a matching angle - should that be pointing 3" down as well... (I thought it was 3" up - but then my drive shaft won't pass through the trailing arms cross member - so I can't be right there) I am extremely outside my comfort zone here.... so much so that I just read article after article on pinion angle that I've stopped making any progress on my build. Any help greatly appreciated.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
