Old 08-13-2013, 03:50 PM   #1
ksshane
ksshane's Avatar
Stock Gages?
My truck just came with the basic gages. Speedo, Fuel, and idiot lights. But the guy I bought my truck from gave me a whole box of extras. Im not sure where all this stuff came from, but its obviously not from my truck.
He gave me 2 extra full gage clusters, and the other two have actual gages for temp and oil pressure (I need to double check and see if one has a tach. Im at work and cant remember off hand).
Is there an easy way to check to see if one of these clusters is fully functional? Or do I have to pull mine out and just hope for the best? What all will I need to change to hook up the temp and oil pressure gages?
Both sets of gages do have the electrical strip along the back.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 08-13-2013, 05:01 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Stock Gages?
Temp sending unit and an oil line.
Its probably quicker and easier to swap clusters than to test the gages.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 08-13-2013, 08:21 PM   #3
In The Ten Ring
Re: Stock Gages?
My truck came with the basic set up too but I've wanted to put the "full guage" package into it for years! One day.....
In The Ten Ring is offline   Reply With Quote
Old 08-13-2013, 09:39 PM   #4
SS Tim
SS Tim's Avatar
Re: Stock Gages?
Its not a plug and play swap. The wires in the harness connector need to be moved around for the gauges to work correctly and IIRC not doing it will burn something out. Try the search button for details on a cluster swap.
SS Tim is offline   Reply With Quote
Old 08-13-2013, 10:04 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Stock Gages?
Here is the link with the connector info.
http://www.gmcpauls.com/Tech%2520Tips1.htm
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
