Old 08-14-2013, 08:45 AM   #1
Sharps40
Re: Parking lamp failures, is LED the fix?
Thanks. I plan to add grounds to my truck this weekend. Its old and ya can't ever have enough good paths to ground. I'm figurin on addin at least...
Hood to firewall.
Cab to frame.
Engine to frame.
Radiator support to frame.
Bed to frame, both sides.
Sharps40 is offline   Reply With Quote
Old 08-14-2013, 08:59 AM   #2
kieth
kieth's Avatar
I kept the old metal bulb socket, cleaned up the outside of the housing with a small grinder, soldered a ground wire to the outside of the housing, put the ground wire into bundle, then routed the ground wire back to a common grounding block. This grounding block is then attached to the frame of the truck with heavy wire. (one at the front one at the back of the truck)
No more grounding problems, did this on every light in the truck, lights are brighter than they have ever been......no more looking around for ground problems hooked to the body of the truck. It may sound extreme but it solves all the grounding issues........Kieth
http://kieth.smugmug.com/Trucks/66-G...H2c2&lb=1&s=X3
where to buy grounding block:
http://www.electricalconnection.com/...tion/02207.htm
kieth is offline   Reply With Quote
Old 08-14-2013, 07:19 PM   #3
Psycho75
Psycho75's Avatar
Wow I really like that ground block I may have to look into that option would help make things much cleaner.
"You can have it Fast, Safe or Cheap. Pick any two"
"If you're gonna be dumb, you better be tough"
1965 C10: http://67-72chevytrucks.com/vboard/s...=1#post6114617
1971 Baja: http://www.thesamba.com/vw/forum/viewtopic.php?t=459552
Psycho75 is offline   Reply With Quote
