Closed Thread
Old 08-11-2013, 07:45 AM   #2676
lazypineapple
lazypineapple's Avatar
Re: What Did You Do With Your Truck Today ?
Squeezed a 4" fan in place of the 2" low profile.
lazypineapple is offline
Old 08-11-2013, 10:41 AM   #2677
mknittle
mknittle's Avatar
Originally Posted by OrrieG View Post
Remembered all the time I spent on stuff no one will see!
My dad often says "nobody will see that" I just say " but I will know about it"
I notice that if there are a line of nice cars/trucks at a show. The one that always stands out even if it doesn't have as nice paint. is the one that has all the nobody will see that's treated like they will be the first thing that will be seen.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 08-11-2013, 08:18 PM   #2678
vht
Done some more body work on the cab of my 51. Can't wait to get all the body work done, I like working on frames, welding, fab work etc, body work sucks.
vht is offline
Old 08-11-2013, 09:06 PM   #2679
OrrieG
OrrieG's Avatar
Hooked up heater hoses to engine and installed electric washer bottle, its from a mid 90's Dodge Caravan back window unit.
OrrieG is offline
Old 08-11-2013, 11:39 PM   #2680
arturo7
arturo7's Avatar
Set up an electrolysis tank using a leaky trash can then de-rusted the radiator frame. Also got out the body hammers and pounded on one of the front fenders.
No pics, the gallery seems to be closed for maintenance.
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline
Old 08-12-2013, 01:50 AM   #2681
spitfire_er
My 55.5 got an electric wiper motor transplant today along with mounting the cab to frame bars in the engine bay. Also got a better e-brake lever installed and put my replacement chrome wiper mounts on the outside of the truck. Last thin I did tonight was getting one of the cab vent cables worked loose.
spitfire_er is offline
Old 08-12-2013, 07:03 AM   #2682
dubie
dubie's Avatar
I drove mine to the exhaust shop on Friday afternoon for a full exhaust set up and an inspection. So I've been sitting all weekend anxiously awaiting its return. I won't be getting it home until Wednesday at least so I should learn a little more patience. But it sure is amazing what you can get done around the house and yard when you haven't got a truck to work on
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Old 08-12-2013, 08:14 PM   #2683
crossfire84
crossfire84's Avatar
put the last coat of poly on my bed boards.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 08-12-2013, 10:43 PM   #2684
mr57
mr57's Avatar
I finally ordered a new master cylinder for my 57. After two years of dripping, it was time....
mr57 is offline
Old 08-15-2013, 12:22 PM   #2685
Russell Ashley
Russell Ashley's Avatar
I finally got a couple of things done that I have been putting off. My Vintage Air dealer thought I needed to mount my condenser closer to my radiator so I got that done by re-positioning the condenser and removing the spacer I had between the radiator and the radiator support so that it moved the radiator closer to the condenser. I also installed a new fan clutch and a shroud which I hope will cure my over heating problem when I'm in traffic with the a/c going.
I also added a windshield visor. I tried to spray it dry to cut the gloss, and even lightly scuffed it with a 3M pad to reduce the gloss and help match it but there's still a difference, although the pic seems to exaggerate the difference. I need to drop the front end some but that's this winter's project.
Russell Ashley is offline
Old 08-15-2013, 02:07 PM   #2686
mechanixman
mechanixman's Avatar
It's looking great russell!
I bought some hub caps a couple days back, Decided to clean one of them up and do a side by side comparison.
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline
Old 08-15-2013, 03:12 PM   #2687
solidaxel
solidaxel's Avatar
Tell me those are two separate caps, and not the same one!!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline
Old 08-15-2013, 05:14 PM   #2688
Dan in Pasadena
Dan in Pasadena's Avatar
Nick,
Outstanding clean up!
000 or 0000 steel wool? Did you paint the letters using the "tape over & cut out letters out with razor blade" method?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline
Old 08-15-2013, 05:20 PM   #2689
Dan in Pasadena
Originally Posted by Russell Ashley View Post
...I also installed a new fan clutch and a shroud which I hope will cure my over heating problem when I'm in traffic with the a/c ...
Russ,
I have the exact same plastic shroud on my '55. When I had it installed one of the old guys that worked on my truck told me the fan blades should only go INTO the shroud 1/3 to 1/2 their width other wise the fan would not be very efficient at cooling. From your photo it's hard to see but it looks like it might be "in" too far.
Old 08-15-2013, 07:50 PM   #2690
davecarney2
davecarney2's Avatar
Dropped the 59' off at the fabricator to get it started. Will start a build thread.
davecarney2 is offline
Old 08-15-2013, 08:46 PM   #2691
Russell Ashley
Originally Posted by Dan in Pasadena View Post
Russ,
Dan, it's the angle of the pic, the blades are centered in the opening. I got that shroud from LMC but had to do a lot of cutting on it to make it fit my radiator and fan like I wanted.
Old 08-15-2013, 09:28 PM   #2692
apache200
apache200's Avatar
Russell where did you get your fan i think im going to run a clutch fan opposed to a electric fan. thanks
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline
Old 08-15-2013, 10:15 PM   #2693
Dan in Pasadena
Oh, ok. I had to use some aluminum spacers to get mine where I wanted it. Works great though. Yours looks nice.
Old 08-15-2013, 11:06 PM   #2694
Nev68
Nev68's Avatar
Lovin' those hubcaps.
Do you know if they will fit on a Chevy Rallye wheel?
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline
Old 08-16-2013, 12:51 AM   #2695
arturo7
arturo7's Avatar
Swapping pieces parts in and out of an improvised electrolysis tank.
(no pics with the gallery down)
ever forward
arturo7 is offline
Old 08-16-2013, 07:57 AM   #2696
Russell Ashley
My engine is a mid seventies 350 and the fan was on the engine when I got it. As far as I know it's the stock fan. I used a thermostatic fan clutch from NAPA, p/n 271305.
FYI: Be sure to get the fan clutch that is correct for your water pump. Some water pumps have a 3/4 inch shaft and some like mine have a 5/8 inch shaft.
Old 08-16-2013, 12:43 PM   #2697
mechanixman
Ha ha yes they are two separate hub caps. But the right one looked almost identical to the left one when I pulled them from the yard.
Nick,
Thank you!
Actually first I (lightly) used a steel wire brush. Then I went to a #2 steel wool. Honestly it's a miracle I didn't scratch the surface. (enough to see it at least)
Others have done the "paint everything, then wipe off the paint where you don't want it." So I thought I'd give it a shot. I taped off the caps right up to the edges of the letters. Then I tried to barely wet the towel and go over everything, but the surface isn't perfectly flat, and I hit the letters, so I repainted it, and spent 20 min with a bunch of cue tips removing the paint.
You know, I don't see any reason why not.
-Nick
Projects:
Old 08-16-2013, 02:06 PM   #2698
Dan in Pasadena
...Actually first I (lightly) used a steel wire brush....
Those things oughta be ALL scratched to hell.
Old 08-16-2013, 03:19 PM   #2699
Rude Dude
Rude Dude's Avatar
Save your money they won't fit ralley wheels the hubcaps use clips and whole size on rear of cap is to big!
Rude Dude is offline
Old 08-16-2013, 03:45 PM   #2700
mechanixman
Ha ha yeah. I kinda help the brush at an odd angle. I think that kinda help not completely scratch em.
I was already planning on getting a new set of these caps, and these were already beat to hell, so I figured I thought I'd just give it a shot.
I stand corrected!
-Nick
Projects:
Closed Thread
