Old 08-15-2013, 08:06 PM   #1
truckdude239
truckdude239's Avatar
fuel filler
I'm trying to find a fuel filler i can mount in my bed floor that uses a 1-3/4 hose and has a 5/8 vent line any ideas/
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 08-15-2013, 09:47 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: fuel filler
You can use exhaust tubing to reduce or splice rubber filler hoses together, essentially as a reducer. You can also just run the vent to a breather or pcv style check ball.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-15-2013, 10:06 PM   #3
truckdude239
Re: fuel filler
Okay so a question on the beather i guess it needs to be higher the the fuel fill or it would over flow when you fill up right?
David fuller
2000 Tahoe 5.3l 378
Old 08-16-2013, 12:54 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: fuel filler
I use a vented cap, so it makes itself the high point in the system more or less. The vent on my old tank was just an AN bung in the top to a piece of fuel hose and a keychain sized PCV filter, the ones that look like mini K&N's. As long as the fuel vapor has a place to go, your fine, just try not to vent it straight into a hot exhaust crossover or something.
This is a picture of a modified setup that a guy with a desert-runner truck made. Its a fuel cell with reducers to the factory Ford filler neck and cap, and he's running a breather as well as the factory charcoal cannistor.
Old 08-16-2013, 10:21 PM   #5
mooseknuckles
mooseknuckles's Avatar
Re: fuel filler
this.....
mooseknuckles is offline   Reply With Quote
Old 08-16-2013, 10:28 PM   #6
truckdude239
Re: fuel filler
do you have a part number or link for that?
David fuller
2000 Tahoe 5.3l 378
Old 08-16-2013, 10:50 PM   #7
mooseknuckles
Re: fuel filler
ridetech clear anodized #81000034
black anodized #81000036
Old 08-16-2013, 10:57 PM   #8
truckdude239
Re: fuel filler
Wow 200 dollars umm wasnt expecting that
David fuller
2000 Tahoe 5.3l 378
Old 08-17-2013, 08:55 AM   #9
mooseknuckles
Re: fuel filler
lol....yeah I should of warned you...
Old 08-17-2013, 06:39 PM   #10
pbr
Re: fuel filler
I put one of the ride tech ones on my nova it fit great and is a quality piece. I held off for a while because of the price. I think you can get a less expensive version at a boat supply place the have used them for years is kinda new to cars and trucks.
pbr is offline   Reply With Quote
Old 08-17-2013, 06:58 PM   #11
clinebarger
Re: fuel filler
I use Marine filler necks all the time, Just fill it slow, They are 1 1/2".....1 3/4" hose will clamp down.
http://www.ebay.com/itm/Stainless-St...a25ae8&vxp=mtr
clinebarger is offline   Reply With Quote
Old 08-17-2013, 07:07 PM   #12
truckdude239
Re: fuel filler
Sweet kk now i need to figure out what i want to do for the vent was told a normal breather was fine but i am worried about fuel dumping out of it
David fuller
2000 Tahoe 5.3l 378
Old 08-17-2013, 07:14 PM   #13
truckdude239
Re: fuel filler
Would this work if i was afraid of fuel spilling out of the vent http://www.iboats.com/Attwood-Fuel-V.../view_id.37945
David fuller
2000 Tahoe 5.3l 378
Old 08-17-2013, 07:28 PM   #14
clinebarger
Re: fuel filler
Mount the vent/breather as high above the tank as possible. Behind a rear tail light maybe??
Old 08-17-2013, 07:31 PM   #15
truckdude239
Re: fuel filler
Yea i guess tbat would make sense
David fuller
2000 Tahoe 5.3l 378
Old 08-17-2013, 10:42 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: fuel filler
The easiest thing I could think of before I changed was just some fuel hose and a breather, zip tied up to the bed cross support.
