Old 08-15-2013, 10:51 PM   #1
forestb
forestb's Avatar
Upper control arm
I am looking to replace a stock upper control arm for a 77 c10 and was wondering who makes the best product? I have already checked Moog but they do not carry that year.
forestb is offline   Reply With Quote
Old 08-15-2013, 11:24 PM   #2
mgchevyparts
mgchevyparts's Avatar
Re: Upper control arm
Rock auto, lowest are $59ea, more expensive about $100ea. complete
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 08-15-2013, 11:30 PM   #3
forestb
forestb's Avatar
Thanks for the quick reply. Is there a specific brand that you recommend?
Old 08-15-2013, 11:39 PM   #4
mgchevyparts
I would buy the least expensive since I would bet they all have cheap ball joints anyway. Upper ball joints last a long time though.
Old 08-16-2013, 07:05 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
What's wrong with the arm you have now ? The reason I ask is that you can rebuild it as cheap as buying a new arm and have much better parts on an original GM arm instead of an offshore part.
Tx Firefighter is offline   Reply With Quote
Old 08-16-2013, 11:29 AM   #6
forestb
forestb's Avatar
I bought the front cross member to install onto my 62 c10 from a junk yard and it was not until I had the upper control arm powder coated and the bushings pressed in that I realized that the control arm was bent where the bushing is, on the right side of the arm. I do not know if I bought it that way or if it go bent somewhere in the proses.
Old 08-16-2013, 11:35 AM   #7
Tx Firefighter
Bend it back ? I've straightened out a few of them over the years. The uppers are easy, lowers much harder to straighten.
Old 08-16-2013, 12:54 PM   #8
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
if your original is not fixable, I would try and find a nice used OEM arm from someone on the parts board and rebuild that. I have bought replacement arms in the past b/c of rust but the they are not nearly as thick as the originals, and I doubt they will hold up as well.
Moog ball joints are the only way to go, in my opinion
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 08-16-2013, 02:20 PM   #9
frog210
I got 2 original 74 front upper control, still has everything on it, bushings, shaft, ball joint, $50 for both upper let me know, they work, just upgraded to porterbuilt
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
