Old 08-14-2013, 11:38 AM   #26
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: Gulfcoast Build Updates (pics)
Originally Posted by BR3W CITY View Post
3/4 DD shaft is a standard size, which 99% of the aftermarket stuff fits. Keep in mind, I hooked up to a tilt column, which started with its own DD shaft stub.
You can page through my build if Photobucket decides not to be a terrorist today.
Because of the angle and combo of parts, I go
Tilt column (3/4 DD) -> DD Universal Joint-> DD shaft-> DD U joint + support -> 72 rag joint stub into steering gear.
The support joint is a special oversized heim joint from AllStar. I have a short video on the bracket fab and installation being edited now and should be out soon.
Ok Cool, Thanks for the info. Much appreciated!!!
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 08-14-2013, 11:45 AM   #27
gulfcoast66
64-66 CHEVY JUNKIE
Originally Posted by Captainfab View Post
This is what I offer to connect the original steering column shaft to the rag joint.
Thanks Captfab, But the parts house by me have a new rag joint I'm goin to go pick up and make this one work today, kinda hard pushing around with no steering
Old 08-14-2013, 11:50 AM   #28
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device. Tackling the wire harness this Morning before it get Hot.. Made me up a transmission and alternater harness..
Old 08-14-2013, 11:52 AM   #29
gulfcoast66
64-66 CHEVY JUNKIE
Old 08-14-2013, 11:54 AM   #30
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device.....
Old 08-14-2013, 11:58 AM   #31
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device. Still need to drop the pan and wire the 4th gear pres switch..
Old 08-14-2013, 12:00 PM   #32
gulfcoast66
64-66 CHEVY JUNKIE
Old 08-14-2013, 08:30 PM   #33
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device. Got the P.S. pump and bracket mounted belt on plus driver side exhaust...
Old 08-14-2013, 08:32 PM   #34
gulfcoast66
64-66 CHEVY JUNKIE
[size=1]Posted via Mobile Device[/size ].
Old 08-14-2013, 09:35 PM   #35
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device. Well my China Made Rag-joint Cracked !! Had it on and it spilt, maybe to small I don't know but never had this happen before!! Going bac to Parts House and Getting My Money Bac and go to Maps!!
Old 08-14-2013, 09:36 PM   #36
gulfcoast66
64-66 CHEVY JUNKIE
*Napa
Old 08-16-2013, 02:52 PM   #37
gulfcoast66
64-66 CHEVY JUNKIE
Update, Still didn't get the steering coupling on the gear box, I brought two rag joints from different Auto Stores and each one was way to small one cracked almost in half..
I just picked up a rag joint rebuild kit and when I get bac in town from work I'm goin to pick a part and get a rag joint to rebuild because my original half the splines are grind down smooth from years of Service..
Have Anybody had Problems with incorrect size Rag joints???? Are having them Crack????
Old 08-16-2013, 02:53 PM   #38
gulfcoast66
64-66 CHEVY JUNKIE
Old 08-16-2013, 04:24 PM   #39
gulfcoast66
64-66 CHEVY JUNKIE
Old 08-16-2013, 04:34 PM   #40
gulfcoast66
64-66 CHEVY JUNKIE
Also I got the front-clip back on.. It's Starting to look like a truck again
Old 08-16-2013, 04:38 PM   #41
gulfcoast66
64-66 CHEVY JUNKIE
Old 08-16-2013, 04:49 PM   #42
gulfcoast66
64-66 CHEVY JUNKIE
Old 08-16-2013, 09:35 PM   #43
Jeff La
looking good
Jeff La is offline   Reply With Quote
Old 08-16-2013, 10:04 PM   #44
gulfcoast66
64-66 CHEVY JUNKIE
Originally Posted by Jeff La View Post
looking good
Thanks Jeff...
Old 08-17-2013, 12:09 PM   #45
gulfcoast66
64-66 CHEVY JUNKIE
Have anyone else had problems with a steering coupling ??? It's a 72 for a 72 here box??? Thanks
Old 08-18-2013, 12:22 AM   #46
Captainfab
60-66 Nut
I don't remember just which one would be correct, but there are 3 different sizes and splines on the steering shaft/couplers. It is possible that the box you have may not really be the year that you think it is. It may have came off of a '72, but someone may have changed it for a different year box sometime in the last 41 years.
Old 08-18-2013, 07:25 PM   #47
gulfcoast66
64-66 CHEVY JUNKIE
That's what I was starting to think Captfab, When I get back home I will pull the gear box and take to auto parts store see if I can have any luck if not then to pick a part and get a good used one...
Old 08-28-2013, 09:04 AM   #48
DREAMER1
DREAMER1's Avatar
Don't kno if it'll help, but I got a gear box and shaft off of my '85 laying around in my garage. Like I said it might help, just let me kno
DREAMER1 is offline   Reply With Quote
Old 08-28-2013, 07:13 PM   #49
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device. Thanks Dreamer1, P.M. sent.....
Old 09-04-2013, 04:30 PM   #50
gulfcoast66
64-66 CHEVY JUNKIE
Well I pulled my front clip back off to work on the steering shaft end and coupling rag joint... Since I had the the front off I decided to wet sand and prime also cleaned up the grill....
