Old 08-17-2013, 10:41 AM   #1
jbgroby
jbgroby's Avatar
Grounding Straps
anyone have a source for grounding straps? I will have the negative battery cable grounded to the block, but I was advised to have at least 1 additional strap grounded from the block to the frame as well. LMC does not list these.
Any pointers for me? How do you have your truck grounded
Jake
jbgroby is offline   Reply With Quote
Old 08-17-2013, 11:05 AM   #2
FetchMeAPepsi
FetchMeAPepsi's Avatar
Re: Grounding Straps
Autozone has 'em right 'chere. Tough too
http://www.autozone.com/autozone/acc...Strap/_/N-25ht
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 08-17-2013, 11:15 AM   #3
hopped up
hopped up's Avatar
Same ones I have. Work fine
hopped up is offline   Reply With Quote
Old 08-17-2013, 11:13 AM   #4
Vernski
Hi Jake check this link out I'm posting there is also a guy on the forums that sells headlight upgrade kits that has ground kits also. I don't have the link to that one but you can find it on the search on the forums..Vernski
http://www.ags.bz/
Vernski is offline   Reply With Quote
Old 08-17-2013, 11:46 AM   #5
Warrens69GMC
Warrens69GMC's Avatar
You can also make yourself a set- I have used 10ga wire with crimped and soldered ends in any length.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-17-2013, 12:03 PM   #6
MusicMan70
MusicMan70's Avatar
http://www.hotrodhotline.com/feature...francisground/
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-17-2013, 12:22 PM   #7
chevyrestoguy
chevyrestoguy's Avatar
One of the most-important, often forgotten items when guys are putting their stuff together. Gotta have em!!!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-17-2013, 12:52 PM   #8
jbgroby
jbgroby's Avatar
Thanks guys that quick will check autozone first then the other sites
Old 08-17-2013, 01:58 PM   #9
VH Coachworks
VH Coachworks's Avatar
Jake
Hi,
We manufacture ground straps for all chevy trucks, so we do have in stock
straps to fit your truck, instructions included for the mounting points.
Part number 6066GSK.
http://67-72chevytrucks.com/vboard/s...d.php?t=511271
VH Coachworks is offline   Reply With Quote
Old 09-09-2013, 02:00 PM   #10
tr4boy
These are just what I need...PM sent!
thanks,
Greg
tr4boy is offline   Reply With Quote
Old 08-17-2013, 02:00 PM   #11
LEEVON
Moderator
LEEVON's Avatar
block to frame, block to cab, frame to body (both cab and bed)
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
