#826 | |
A day late and $1 short...
Re: Project "Just an Old Truck"
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#827 |
Well, I wasted the better part of a day painting the firewall plates with paint that was way too expensive and didn't turn out the way I wanted. When they are good and dry I'll scuff them up and shoot them with some cheap semi-gloss black.
#828 |
![]() Join Date: Apr 2012
What happened with the paint?
Posted via Mobile Device |
#829 |
I ordered gm paint code 503 in an aerosol can from Automotivetouchup.com and it is just a little too fresh compared to my not so fresh firewall.
#830 |
![]() Join Date: Dec 2006
Sorry to hear about the paint Buck. I'm hitting a similar snag on my truck trying to pick up where my father left off with the bodywork. He is no longer able to do it due to medical reasons and well I'm certainly no bodyman and can't afford to just drop it off at a shop to do.
On a side note looking at your picture, you could probably mask everything off in the engine compartment, clean up your firewall and spray the whole thing, that way it would be uniform looking. You could even do it semi gloss black if you didn't want to do the light green. Did you have to clear over the green when you sprayed it or is that straight out of the can. Posted via Mobile Device
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#831 | |
#832 |
![]() Join Date: Jul 2009
Just read this entire thread in one sitting. Wow, super nice truck!!!
Why r u getting rid the the PB rear stuff? Air? Posted via Mobile Device |
#833 |
Thanks for the compliment, you couldn't have better timing I needed to hear something nice about the truck. I am so PO'd at the truck right now I had to come in and calm down a bit. Things are just not going well today...
I am just going to go a different route to make it handle, it will be PB parts but no air.
#834 |
Trailing arms should be great for handling... I'd think anyway. Wish I had the $ for that setup.
![]() Posted via Mobile Device |
#835 |
Nothing cosmic, just some good shocks mounted in the right spots and sway bars.
#836 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Looking great!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#837 |
#838 | |
I have a radical idea!
Awesome truck!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 08-15-2013 at 10:37 PM. |
#839 | |
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 08-16-2013 at 12:16 AM. |
#840 |
Hey buck. Was just going back looking through your thread. And noticed you went with this external trans cooler. Did you also run it thru the radiator?? Also Seems like you used -8 lines or -6 ??
Truck looks great !! ![]() Posted via Mobile Device |
#841 |
I did not run mine through the radiator. It is an AFCO heat-sink style cooler mounted on the passenger side frame rail, and is connected using -6 braided hose.
#842 |
Thanks for clearing that up. That's exactly what I have. But some guys were saying I had to run it through the radiator. Also.
Thanks again. Keep trucking... ![]() Posted via Mobile Device |
#843 | |
#844 |
Made some progress with the A/C today, wiring is connected but needs to be made "neater" and the flexible ducting is in, what a PITA! Well, because
#845 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Great work.
#846 |
Looks great. Tight fit huh!?!
#847 |
No doubt!!! No glove box space there.
#848 |
Nice work sir!
-Rus |
#849 |
Nice job Buck
#850 |
Thanks guys for keeping me pumped up.
