Closed Thread
Old 08-17-2013, 07:52 AM   #7701
sboris
sboris's Avatar
Re: What did you do to your truck today!
Originally Posted by BugzC10 View Post
Installed Taylor spark plug wires and looms. Had to cut to length and crimp on connector/boots. Initially it was a PIA to get the wire through the boot, but once I figured out that liquid soap and a pair of hemostats were the ticket they went together easily.
Before:
After:
Looks nice..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline
Old 08-17-2013, 09:53 AM   #7702
VWNate1
VWNate1's Avatar
Post Re : Brake Drum Service
I took Bendix Factory brake service training (they're the folks who designed your brakes) and they were adamant that Mechanics NOT automatically turn the brake drums because each time you do this , you remove metal that's important to have so your brakes dissipate heat properly and don't fade just when you need them the most ~
They said the only time you should turn / machine brake drums is when they're so out of round they cause brake pedal pulsations or if they're bell mouthed over .020" .
When asked what about when the shoes went metal to metal , he said usually this means the drum is way past spec so it's junk anyways , if you *must* re - use it , use some really coarse sand paper etc. to remove the sharp edges in the grooves then mount it up , the new shoes will bed in to the grooves and actually make the brakes work better .
I trust the Engineers who designed the brakes more than the old guy who tried to teach me to turn the drums every time , in the end this only sells more drums and puts dangerously thin drums back on the street .
-Nate
Originally Posted by In The Ten Ring View Post
I picked up my renewed gas tank today and I must say, it does look impressive. I still think I'll go on and order a new one, just to be sure.
I also called around and found a service center that will turn my drums for $15.00 each.
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-17-2013, 07:09 PM   #7703
In The Ten Ring
Well thanks man! That's why I joined this site, to get info I couldn't get elsewhere for the same price.
I'll hold off on the drum turning....
I did get one coat of red primer on my "renewed" gas tank. I hope to finish it tomorrow depending on the weather.
I plan to paint the tank "hammered" silver as that might look about what it did before I had it cleaned up and I'll paint the nozzle black.
In The Ten Ring is offline
Old 08-17-2013, 08:10 PM   #7704
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Wait ~ if you took it to the " Gas Tank Renew " franchise dealer , they're supposed to paint it inside and out , all you needs do is choose the silver / grey color you like and it's good to go pretty much forever as that's the guarantee :
LIFETIME .
Be aware that all new tanks are Chinese carp ,most either leak at the poorly welded seams now or will in less than one year , I highly suggest the Gas Tank Re New solution , more $ yes but it's right .
To - day I tossed some empty deposit bottles into my '69 C/10 Stepper as I walked past it , then I purchased a $600 Motocycle 100 + miles away so I guess I'll be Desert bound next week to collect that .
-Nate
Geezer
VWNate1 is offline
Old 08-17-2013, 08:43 PM   #7705
In The Ten Ring
Hmm.....well then....maybe I should save another $150.00 and just use my old tank then!
The guy offered to coat the outside with black material, undercoating was what it was, as "most gas tanks we fix are mounted under the frame" but I opted out since I wanted to keep the original look and I was fearful they'd get some down into the lock ring area.
He warranted the work for two years and did say the "renew" material has a lifetime warranty.
OK man...I do value opinions here....but I'd been told both ways on this one: one party thinks I should get a new tank and others think I did the right thing getting this one fixed.
Old 08-17-2013, 09:09 PM   #7706
67_C-30
I have a radical idea!
67_C-30's Avatar
Installed a new bedside. The old bedside was warped from fire.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline
Old 08-17-2013, 09:32 PM   #7707
kcsa75
kcsa75's Avatar
Before:
After:
Looks like a million dollars. I bought the same loom this week.
Where abouts on the Space Coast? I used to live in Palm Bay.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline
Old 08-17-2013, 09:35 PM   #7708
kcsa75
kcsa75's Avatar
I put new rear brakes, including new Bendix drums, on my truck. I've replaced pads on lots of disc brakes, but this was the first time I've ever done shoes.
Willie
'72 C10 Highlander
kcsa75 is offline
Old 08-17-2013, 09:52 PM   #7709
VWNate1
VWNate1's Avatar
Thumbs up Re : What did you do to your truck today!
As I said : new tanks are made in China by pi$$ed off slave laborers on work camps , from basically tin foil .
You're wanting to put 18 gallons of gasoline behind your seat in tin foil ?! .
The choice is yours .
FWIW , the black stuff re new uses , isn't really undercoating , it's just thick to resist stone chipping .
You can always $pend the $150. later or , get a good used tank from one of the many who Hot Rod their rigs & re locate perfectly good gas tanks under the bed etc. , usually amazingly cheaply .
For reasons I'll never understand , used gas tanks are *very* hard to sell ~ I tried to GIVE AWAY my spare '49 ~ '53 Chevy truck gas tank for over 20 years before giving it to my local scrap guy .
I'm sure you'll be well pleased with the re new'd one .
-Nate
-Nate
Geezer
VWNate1 is offline
Old 08-17-2013, 10:02 PM   #7710
effects66
effects66's Avatar
Installed the hydraboost and Wilwood Master cylinder
plus tried an air cleaner out, not sure if I like it yet
[/QUOTE]
My 1970 c10 (550hp LSX, 4l80e, full Ridetech)
http://67-72chevytrucks.com/vboard/s...d.php?t=556610
effects66 is offline
Old 08-17-2013, 11:09 PM   #7711
JJanzen
JJanzen's Avatar
Way Sexy!!!
QUOTE=effects66;6217391]Installed and connected all gauges...
And buttoned up all fluid connections.....
and connected all linkages...
[/QUOTE]
Blue72
Red72
JJanzen is offline
Old 08-18-2013, 02:29 AM   #7712
jayman68
Fun Stuff
jayman68's Avatar
A couple weeks ago, at the street fair in town, there was a vendor that makes signs out of license plates. I ordered one to go with my truck, then I picked it up today at the street fair in Concrete, WA.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline
Old 08-18-2013, 09:51 AM   #7713
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
QUOTE]
no wonder they stink!
Tom Vogel is offline
Old 08-18-2013, 04:21 PM   #7714
In The Ten Ring
I just put the second coat of primer onto my renewed gas tank.
Old 08-18-2013, 08:38 PM   #7715
Expat_dude
Expat_dude's Avatar
Got glove door painted in satin black, will add some subtle art to it later on. Vintage AC is installed and chilling !!
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline
Old 08-18-2013, 08:50 PM   #7716
SuperC10Tex
SuperC10Tex's Avatar
Started to add a little red "Touch" today!!!
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline
Old 08-18-2013, 09:25 PM   #7717
bobbydigital
bobbydigital's Avatar
somewhere on here, i read about using 0000 steel wool for cleaning windows. today i tried it out and found that it worked great. now that the windows are clean, i was able to start tinting. got the rear and the vent windows done before running out of light and had to get more tint
bobbydigital is offline
Old 08-18-2013, 10:40 PM   #7718
mud.man.rj
mud.man.rj's Avatar
Never heard that about steel wool, better than the chemicals I use, have to keep it in mind for future use.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 08-18-2013, 10:47 PM   #7719
SCHRUMGMC
SCHRUMGMC's Avatar
I cleaned out the vent's, cowl and under the Bench...The amount of Filth and stuff under the bench was out of this world...It looks a whole lot nicer than it did few weeks ago..I cleaned under the Tailgate and it was so dirty it was unbelievable
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 08-19-2013, 02:19 AM   #7720
swamp rat
swamp rat's Avatar
Ordered new seat cushions and a cover.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline
Old 08-19-2013, 02:56 AM   #7721
SCHRUMGMC
SCHRUMGMC's Avatar
I plan tomorrow to finish putting the Tires on and have it towed to the Mechanic
1971 GMC Sierra
1959 GMC 100
Old 08-19-2013, 04:25 AM   #7722
pancho's 67
pancho's 67's Avatar
Finally found the time to fix my fuel pump problem. The LS engine is perfect under the hood and I drove it home from my work shop and it's sitting in my driveway.
pancho's 67 is offline
Old 08-19-2013, 09:57 AM   #7723
VWNate1
VWNate1's Avatar
I filled it up , topped off the oil , checked the coolant & ATF , washed the widows (BTW : try White Vinegar before using # 0000 or finer steel wool) and headed off to Yucca Valley , it's only a couple hundred miles , by the time I arrived there @ 10:00 AM it was 99° F & didn't get any cooler .
I had a nice breakfast @ C & S Coffee then bought and loaded up another old Motocycle I'll fix up for re sale ~ I'm gathering $ for my new cab (whenever I find one) and total re paint .
Pix are of the Moto after I loaded it .
In the end , it's nothing special nor new , just another old beat to shyte CHEVROLET Light Duty Truck out earning it's keep long after those wretched Brand 'F' rigs are all junked .
-Nate
Geezer
VWNate1 is offline
Old 08-19-2013, 02:50 PM   #7724
In The Ten Ring
(Love seeing pics of that green stepside VWNate!)
I ran by Lowe's and picked up some springs to try and replace the broken spring on the parking brake handle. Either size worked fine so I picked the smaller of the two as it was closer to the original. Probably the easiest fix on this whole job!
I'm dying to go out and paint the gas tank but I'd better get other things done.
Old 08-19-2013, 03:13 PM   #7725
DT1
DT1's Avatar
Looks like about a 1970 CL90
DT1 is offline
Closed Thread
