Old 08-17-2013, 05:09 PM   #1
gabe2000
Add-on pulley for AC???
This is my last change to tried to investagate if adding AC to chevy 250(easy/cheap). I saw at thepartguy.com sells this add-on pulley. This is realiable or has somebody tried this???
My chevy 250 engine is running with 2 grooves pulley but before I a sanden compressor/AC system, I need to know if this possible. An easy solution without adding pulley to Alt, steering pump or installing 3 grooves pulley.
Please lookName:  64-68SBCCrankPulleyPSGroove(2-groove-ShortWP).jpg
Size:  86.3 KB at the pics one is for crankshaft and other is water pulley.
gabe2000 is offline   Reply With Quote
Old 08-17-2013, 05:11 PM   #2
gabe2000
Re: Add-on pulley for AC???
Old 08-17-2013, 05:12 PM   #3
gabe2000
Is it worth all the trouble having Inline6 with AC???
Old 08-17-2013, 05:14 PM   #4
gabe2000
this looks like add-on??? but will the outer groove line up with the AC???
Old 08-17-2013, 05:54 PM   #5
chevyrestoguy
chevyrestoguy's Avatar
I would get ahold of the seller and ask some questions. They might be able to help. I can't see the pulley being a problem. The biggest issue with an aftermarket A/C is the fwd-aft placement of the compressor, which will determine if the belt will align with the A/C pulley on the crank.
The older I get, I'll do whatever it takes to put power steering, power brakes, and A/C on everything I have, so my answer is YES.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-18-2013, 12:35 AM   #6
Captainfab
60-66 Nut
That pulley looks to be the same pulley used on the small block with a short water pump, for driving the power steering pump. I don't remember for sure, but it seems like that does bolt up to the 230/250 balancer/pulley assembly.
Old 08-18-2013, 07:55 PM   #7
yelmer
I have a factory ac compresser bracket for a 6 came off a 292 i will need to check i think i might have the pulleys? If somebody is looking?
yelmer is offline   Reply With Quote
