Old 08-18-2013, 08:40 PM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
3/4 ton front axle question
I have an 87 3/4 ton. the u joint on the rh axle is all wiped out. so I need to change that axle, ...or I have an 84 3/4 ton that I could just swap out both the front and rear differentials... ( the truck right now has the brakes disconnected, so that part is not an issue)...
the issue: the 84 is a full time 4x4, and the 87 has locking hubs....
is it pretty simple to put the locking hubs on the 84 axle?
or not?
will it interchange?
thanks for any info!
Old 08-18-2013, 09:29 PM   #2
79Betty
79Betty's Avatar
Re: 3/4 ton front axle question
If they are bot the same axle (I.E. both 10 bolts) yes they will.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 08-18-2013, 10:14 PM   #3
BONUSCAB
Um, if it needs a u-joint, why not just put a u-joint in it?
BONUSCAB is offline   Reply With Quote
Old 08-18-2013, 11:07 PM   #4
Zane M
Now why would you want to present what seems to be a logical and easy answer to the problem?
Zane M is offline   Reply With Quote
Old 08-19-2013, 12:13 AM   #5
jonzcustomshop
1961 crewcab
maybe I should have explained it better, the axle is trashed, the once round holes for the ujoint are egg shaped...
so, I looked into what it would take to change the axle... and since I don't have the tools to take the inner hub apart, and don't know what spline the axel is , or have a spare besides the 84 I was thinking it might be cheaper and easier to just swap the differentials.....
this is a point A to B vehicle , nothing special, I just need 4X4 that works...
Old 08-19-2013, 12:14 AM   #6
Rubble
or not?
You sure the full time is not just the auto hubs? I didn't think GM offered full time 4x4 after 1980. If you can post a transfer case picture,that will pretty much tell too...
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 08-19-2013, 12:15 AM   #7
jonzcustomshop
1961 crewcab
thanks, will have to see, I know the 87 is a 10, will have to check the 84
Old 08-19-2013, 12:18 AM   #8
jonzcustomshop
1961 crewcab
hmmm, I will look and see, this 84 still has the hubcaps on it, and the hubs just have the chrome cap with the 4X4 sticker on it.
(just did a quick google search of "auto hubs" and I am sure that is what it has!)
Old 08-19-2013, 12:43 AM   #9
Rubble
Ya,believe it was available from 81 on in the 1/2&3/4T models.It's not to hard to convert to full manual locking hubs,done a couple of mine.
Old 08-19-2013, 01:37 AM   #10
andrewmp6
Is the gearing the same on both axles?
Old 08-19-2013, 03:23 PM   #11
jonzcustomshop
1961 crewcab
not sure.. I was just going to swap the front and rear out of the 84 into the 87 to keep the factory ratios together..
