Old 08-15-2013, 11:49 PM   #1
*71SWB*
Here I go again needing help (dash cluster)
I still haven't picked the truck up yet and will post pics as soon as I get it on Sunday or Monday.
I have found a dash cluster with a tach and a vacuum gauge. Again, being the non-mechanic, will the tach and vacuum gauge work on my truck? Will I need anything other than the replacement dash cluster?
I keep finding things I want to buy for the truck.
*71SWB* is offline   Reply With Quote
Old 08-16-2013, 12:22 AM   #2
farmall
farmall's Avatar
Re: Here I go again needing help (dash cluster)
And the truck is???
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 08-16-2013, 12:29 AM   #3
leddzepp
Moderator
leddzepp's Avatar
The tachometer uses a separate wiring harness. They are readily available from many vendors. The vac. Gauge is mechanical and will need to be plumbed to a source on the intake manifold via a hard line, as a rubber line will collapse under vacuum.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-16-2013, 06:36 AM   #4
*71SWB*
Truck is a 1971 Chevy C10 SWB
Thanks for all the info
Old 08-16-2013, 12:13 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
If you had a gauge cluster to start with you'll have to add the vacuum lin and the tach harness and just plug it into the harness. If you had a three gauge cluster with the idiot lights then you'll have to change the wiring around in the plug plus add the wires for the battery gauge.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-18-2013, 11:44 PM   #6
*71SWB*
Thank you for the info
