Closed Thread
Old 08-19-2013, 02:56 AM   #1
SCHRUMGMC
SCHRUMGMC's Avatar
Re: What did you do to your truck today!
I plan tomorrow to finish putting the Tires on and have it towed to the Mechanic
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 08-19-2013, 04:25 AM   #2
pancho's 67
pancho's 67's Avatar
Finally found the time to fix my fuel pump problem. The LS engine is perfect under the hood and I drove it home from my work shop and it's sitting in my driveway.
pancho's 67 is offline
Old 08-19-2013, 09:57 AM   #3
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
I filled it up , topped off the oil , checked the coolant & ATF , washed the widows (BTW : try White Vinegar before using # 0000 or finer steel wool) and headed off to Yucca Valley , it's only a couple hundred miles , by the time I arrived there @ 10:00 AM it was 99° F & didn't get any cooler .
I had a nice breakfast @ C & S Coffee then bought and loaded up another old Motocycle I'll fix up for re sale ~ I'm gathering $ for my new cab (whenever I find one) and total re paint .
Pix are of the Moto after I loaded it .
In the end , it's nothing special nor new , just another old beat to shyte CHEVROLET Light Duty Truck out earning it's keep long after those wretched Brand 'F' rigs are all junked .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-19-2013, 02:50 PM   #4
In The Ten Ring
(Love seeing pics of that green stepside VWNate!)
I ran by Lowe's and picked up some springs to try and replace the broken spring on the parking brake handle. Either size worked fine so I picked the smaller of the two as it was closer to the original. Probably the easiest fix on this whole job!
I'm dying to go out and paint the gas tank but I'd better get other things done.
In The Ten Ring is offline
Old 08-19-2013, 03:13 PM   #5
DT1
DT1's Avatar
Looks like about a 1970 CL90
DT1 is offline
Closed Thread
