Old 08-18-2013, 10:13 PM   #1
buddylj1990
got my truck running but almost had a huge problem rocker popped off push rod
yesterday got my truck running it was running good didn't have no valve rattle but got up today to drive and tryed starting it didn't sound right so got it running and it was sippin tappin so shut it off pulled valve cover off 4 rockers were really loose two on driver side and 2 on passenger side one on the passenger side was so loose it had jumped off push rod and one on the driver side was so loose it wasn't touching push rod spring so i ajust them and now it runs real good on all eight cylinders
buddylj1990 is offline   Reply With Quote
Old 08-18-2013, 10:26 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: got my truck running but almost had a huge problem rocker popped off push rod
Sweet. Hope they stay that way now! Glad it was a simple fix for you.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 08-18-2013, 10:57 PM   #3
jjzepplin
jjzepplin's Avatar
I would be concerned about why this happened. Studs coming out of the head or worn threads? If this happens again while driving...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-18-2013, 11:00 PM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
Either that, or you have some valves sticking from sitting up. How was it running? Was it skipping?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-18-2013, 11:18 PM   #5
buddylj1990
ya it was skipping a little but thought it was maybe the old gas or some trash in the carb but its not missing a beat now i don't know cause it didn't look like the studs were coming up and the threads wasn't screwed up. maybe someone trying to adjusting valve not knowing what there doing
Old 08-19-2013, 09:01 AM   #6
slomotion
Old Duffer
slomotion's Avatar
If you're running hydraulic lifters and some trash got in them, they may have collapsed (spring pressure pushed the oil back out of them,) be careful that they're not too tight now.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 08-19-2013, 09:30 AM   #7
buddylj1990
it pulling the stud out what do i do
Old 08-19-2013, 09:52 AM   #8
jjzepplin
jjzepplin's Avatar
Well first put a straight edge across all the studs. They should all be at the same height. If that is ok then I would inspect further maybe into the lifters. Was this engine running well in it's history or did you just acquire it? Something is up and you need to know what that is.
If it is the studs they could be pinned or swapped for screw in but that will be hard to do without removing the heads. Metal could easily get into the engine.
Old 08-19-2013, 03:58 PM   #9
buddylj1990
heres what its doing i pushed it back in with lock tight few mins. ago ain't coming loose yet i ran yesterday thinking they only need adjusting and it ran real good but this morning went to start it and it pulled the stud thats when i found out it was pulled stud
Old 08-19-2013, 04:41 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Only way to fix a pulled stud is by either pinning them through the stud boss on the head, or having screw in stud installed. I've pinned studs with the head still on the engine in the rig. Not sure what your mechanical abilities are, but it can be done yourself.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-19-2013, 08:53 PM   #11
bbcmudtruck
I'd either buy a set of ready to bolt on heads with screw in studs or take your heads to a shop and have them tap and thread in some arp studs. While your at it, might as well freshen them up! However by the time you buy gaskets, studs, pay for shop work and freshen the heads, you can usually find a good set of 2.02/1.60 heads that are ready to bolt on for $500 bucks or less.
bbcmudtruck is offline   Reply With Quote
Old 08-19-2013, 08:54 PM   #12
bbcmudtruck
Also, if your running a hydraulic cam, be sure to add some zinc additive to your oil. The newer motor oil doesn't have enough zinc in it to keep hydraulic cams alive. Also, pull all of your push tubes and blow through them with an air gun.
Old 08-20-2013, 09:26 AM   #13
buddylj1990
im going to pin them this weekend
Old 08-20-2013, 12:25 PM   #14
GASoline71
GASoline71's Avatar
You mean flat tappet cams. Hydraulic and solid.
There are hydraulic roller cams as well.
Gary
