08-12-2013, 03:37 PM | #26 |
Re: Blazer SPID thread?
GMC Jimmy and Chevy Blazer the real mans convertible. |
08-13-2013, 05:51 PM | #27 |
I think the Heavy Duty Aux Seat is actually the passenger seat. A passenger seat was optional as was the rear seat. My K5 has the same two options for seatings as yours.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-13-2013, 06:29 PM | #28 |
The one standard seat is a driver's HD/utility seat. The AN3 adds a passenger HD/utility seat without a console. The upgrade A50 bucket seat option replaced the driver's seat with an upgrade bucket seat and added a matching passanger seat with center console.
The AS3 rear seat option was a three passenger bench seat that was matched to either front seat option. The standard cover or the upgrade CST cover.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-13-2013 at 06:49 PM. Reason: can't code today |
08-13-2013, 06:37 PM | #29 |
wow thats cool to know thanks SS Tim and thanks Yukon Jack for the help.
08-17-2013, 07:22 PM | #30 |
Carpe manana
Folks it looks like we have a CST Highlander here!! What color plaid would be installed on this bronze K5?? If the chrome hub caps were an option, what came standard on CST vs. base model K5's? Full wheel covers were optional I assume.
08-17-2013, 07:58 PM | #31 |
Pete,
Too easy, code 671 is a CST/Highlander w/grey inserts. Per the color chart that was the only "recommended" plaid combination on a 522 bronze Blazer. The standard CST hub caps were the painted version. The P03 caps were optional on all Blazers with compatible wheels. The P01 wheelcovers were available on 4x4 or 4x2 versions. On 4x2 Blazers you could also order PA1 wheelcover. Not sure which caps or covers were standard with the "package" Highlander Blazers (YG6-8), as the literature only mentions the pickup covers/caps directly. However it is possible 4x2 package Blazers were PA1 wheelcovers and 4x4 Blazers were P03 as part of the savings package.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-19-2013 at 12:52 PM. Reason: clarity |
08-17-2013, 08:32 PM | #32 | |
Carpe manana
08-18-2013, 01:20 PM | #33 |
Carpe manana
72 cst - I'm now of the mind that only Flint and St. Louis built K5's
08-20-2013, 10:49 AM | #34 |
Good move, I'd like to reproduce my original SPID as well. Guessing you bought a blank reproduction & completed the details yourself? I think the most difficult part of the process would be finding a working type writer. Maybe a print shop?
08-20-2013, 09:26 PM | #35 | |
Carpe manana
Anyone notice that in Tim's posted GM add above it indicates that "water-proofed" clusters and ignition bezels came on K5's (listed under STANDARD interior)? Really?
08-20-2013, 11:19 PM | #36 |
Carpe manana
Not a SPID but here (http://67-72chevytrucks.com/vboard/s...d.php?t=168345) is a list of RPOs from a K5 that include an auxiliary battery. I can understand an aux battery on a truck with a camper - but a K5? Not many 1/2 ton trucks seem to be so equipped.
AS3-Rear Seat A68-Rear Center Seat Belt B93-Door Edge Guards DF2-Camper Mirrors-Stainless F76-Front Wheel Lock Hub LS9-350 Cu In V-8 Engine NA4-Skid Plate PV6-H78x15 Belted White TP2-Auxiliary Battery V37-Front and Rear Chrome Bumpers Z58-Auxiliary Top-White 668-Black Vinyl Trim AN3-Heavy Duty Auxiliary Seat A11-Tinted Glass BX2-Body Side Molding-)W)ide? C60-4-Season Air Conditioning F51-Front and Rear Shock Absorber G80-Positraction Axle M49-Turbo Hydra-matic N40-Power Steering PO1-Full Wheel Covers U63-AM Pushbutton Radio Z53-Ammeter-Oil-Temp Gauges 524-Hugger Orange
08-21-2013, 12:08 AM | #37 | |
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
08-21-2013, 06:23 PM | #38 | |
Carpe manana
08-22-2013, 12:07 AM | #39 |
Carpe manana
71 Jimmy very nicely optioned to include aux battery.......@Tim: ever seen a truck w an aux battery AND overflow tank on the SPID - seems incompatible. Let's see more Jimmy's....
08-22-2013, 01:15 AM | #40 | |
Root Beer or Dog Food, tough choice but I will have to go with the dog food. :-)
The only period vehicles I can recall seeing RPO V10 on were fleet/medium duty trucks. But I do know of a TP2 truck with an added overflow tank. It was installed on the right as expected and the washer bottle had been relocated back to the left side.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-22-2013 at 02:05 AM. |
08-22-2013, 01:51 AM | #41 |
Carpe manana
Tim - Dog food it is then. We couldn't come up with a adequate location for a GM coolant recovery tank on my K20 with the TP2 aux battery installed. It would have to ride so high to clear the inner fender posterior to j-blocks on either fender that I believe the hood would contact it when closed. I wanted it to work - may use it on my K5.
Here's the only SPID I know of that lists an RPO coolant recovery tank (I want one of those listed magnet plugs). Maybe a fleet truck?:
08-31-2013, 05:46 PM | #42 |
A new SPID for my collection. Of course sometimes the "dealer installed" options are pure frosting.
08-31-2013, 09:21 PM | #43 |
Carpe manana
Nice example Tim - how about a pic of an Eagle Feathers accessorized Blazer!
08-31-2013, 10:41 PM | #44 |
Pete,
Don't have any "good" pictures of the Blazer this came off of but I will look through my stash. To hold you over here is a print ad for the Mod Bods sticker packages. A flyer too.
09-05-2013, 10:02 PM | #45 |
Carpe manana
Here's another 72 CST with 16.5" wheels. St. Louis K5:
09-14-2013, 12:40 AM | #46 |
Carpe manana
72 St Louis K5 CST A/C with 3.73 gears
11-15-2013, 11:21 PM | #47 |
Carpe manana
Found this one in a salvage yard:
11-15-2013, 11:29 PM | #48 |
Carpe manana
A 2wd here....I wonder why 2wd's weren't badged as "C5"
11-16-2013, 12:15 AM | #49 |
Carpe manana
Another 2wd:
11-16-2013, 07:48 AM | #50 |
I can't read mine so not worth posting. Some of you guys have some great
Options. |
