So I picked up a 1981 GMC K1500 and the motor has short valve covers with center bolts. Like a lot of other folks out there, I'm just trying to start off with doing a few little things at a time to my new girl! As I started searching around for some new covers, I've been thrown a little bit of a curve ball, to me anyway. The option of baffled versus non-baffled valve covers! I understand the difference, but does it matter? Which is better? And what about tall or short?
Thanks in advance, John Last edited by RocketCowboy; 08-21-2013 at 02:38 AM. |
#2 | |
Re: To baffle, or not to baffle...Valve Covers
This is my opinion. Frank Posted via Mobile Device
Born and proudly residing in a Red State ! |
![]() Join Date: Jun 2012
Baffled for sure. If you need the clearance for an aftermarket valve train go with the tall, if not the short ones will do...
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
Baffled are better and short vs tall is easy you use short unless you have roller rockers then you go tall.
