Old 08-22-2013, 09:44 AM   #1
mknittle
mknittle's Avatar
Re: cross sills not drilled!
When it's all said and done it will just be another hour added to the build time of the truck.[/QUOTE]
that's what happens to mine. The problem is it multiplies and I can't stop itthem add the while I am at it...........
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-22-2013, 05:25 PM   #2
mr48chev
mr48chev's Avatar
I'm the guy who got the longest time unfinished award at the unfinished nationals several years ago and the truck isn't anywhere close to even being drivable let alone finishe.
The good part about this is he is only out time and maybe the cost of a drill bit but doesn't have to dig way down into the build kitty for something he hadn't planned on. I'd mark and drill one and make sure everything is right on it and then use it as the drill guide for the others. That way the holes are perfectly aligned from sill to sill all the way back.
My ongoing truck projects:
Old 08-23-2013, 10:30 AM   #3
mknittle
mknittle's Avatar
yeah, even if he has to mark and drill the first one the rest will go easy. I am one to get sidetracked I started to fix a crack in my dash and ended up building a steering column
Mark
My GMC build.
