Old 08-23-2013, 08:00 PM   #1
bbbc10
Diggin The SquareLife
cpp 6 lug rotors on a 84 silverado
I wana convert my front suspension to 6 lug I knw the cpp rotors will swap over but they are for heavy duty brakes an I have the light duty 1" rotors on my truck...I knw I will have to swap over to the heavy duty rotors but wht else would I have to swap? any part numbers or parts list will be great thanks!
bbbc10 is offline   Reply With Quote
Old 08-23-2013, 08:13 PM   #2
mgchevyparts
mgchevyparts's Avatar
Re: cpp 6 lug rotors on a 84 silverado
You will need spindles and calipers to match the 1.25" rotor. Lots of money to just go 6 lug.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 08-23-2013, 08:33 PM   #3
jitteryguy
GoatLube Experss
jitteryguy's Avatar
six lug conversion would be cool for my CCSB, I Google'd it but cant find the CCP rotor's you mention. can you post a link.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 08-23-2013, 09:39 PM   #4
bbbc10
here are some that will work
http://www.earlyclassic.com/catalog.aspx?ProductId=205
I cant find the link for the cpp rotors if I do I post it up
Old 08-23-2013, 11:18 PM   #5
mgchevyparts
6 lug rotors are just 5 lug 1.25" rotors that are drilled with 6 lug at the manufactuer in China. You can't redrill 5 lug rotors.
Old 08-24-2013, 10:34 PM   #6
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I can get Mcgaughy's 6-lug rotors .. along with a drop spindle to fit the rotor.... Skys the limit ....You can do upgraded calipers etc....or stock ..etc. Bearings and small parts like lines are part store items
ksbrktracer is offline   Reply With Quote
Old 08-24-2013, 11:15 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
You will need:
HD spindles
HD calipers
And the inner bearings for the rotors are different.
(you will need a A5 inner bearing for the HD spindles)
Keith
Convert to disc brakes.
Old 08-25-2013, 04:11 PM   #8
bbbc10
thnks for the info an for front when time comes think ima buy a kit and rear im still searching for ideals, swaping 4x4 axles or 4x4 rear end
