Diggin The SquareLife
cpp 6 lug rotors on a 84 silverado
I wana convert my front suspension to 6 lug I knw the cpp rotors will swap over but they are for heavy duty brakes an I have the light duty 1" rotors on my truck...I knw I will have to swap over to the heavy duty rotors but wht else would I have to swap? any part numbers or parts list will be great thanks!
Re: cpp 6 lug rotors on a 84 silverado
You will need spindles and calipers to match the 1.25" rotor. Lots of money to just go 6 lug.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
GoatLube Experss
![]() Join Date: Oct 2009
six lug conversion would be cool for my CCSB, I Google'd it but cant find the CCP rotor's you mention. can you post a link.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
here are some that will work
http://www.earlyclassic.com/catalog.aspx?ProductId=205 I cant find the link for the cpp rotors if I do I post it up |
6 lug rotors are just 5 lug 1.25" rotors that are drilled with 6 lug at the manufactuer in China. You can't redrill 5 lug rotors.
TNT-MOTORSPORTS
I can get Mcgaughy's 6-lug rotors .. along with a drop spindle to fit the rotor.... Skys the limit ....You can do upgraded calipers etc....or stock ..etc. Bearings and small parts like lines are part store items
67-72 parts collector,…
![]() Join Date: Nov 2002
You will need:
HD spindles HD calipers And the inner bearings for the rotors are different. (you will need a A5 inner bearing for the HD spindles)
thnks for the info an for front when time comes think ima buy a kit and rear im still searching for ideals, swaping 4x4 axles or 4x4 rear end
