08-23-2013, 11:01 PM | #1 |
oil leak
I have a weird oil leak somewhere. I thought it was coming from the valve covers so I got new felpros and put them on. Still see the oil. So I got those spreader things and some longer screws and put them on today. Still leaks.
Its pooling in the intake manifold crevice right under the carb. You can kind of see it here. Heres where it is on a plain intake I also keep seeing a drip on the bottom of the starter. Could it be anything other than the valve covers? Is there oil going through the intake? could it be cracked? Theres no oil passages above that point is there? |
08-24-2013, 12:17 AM | #2 |
Re: oil leak
Those intake bolts go into the lifter valley and need to be sealed. This is a very common leak point.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
08-24-2013, 12:19 AM | #3 |
Re: oil leak
oh crap i didnt know that. So do I have to take the covers back off or can I goob the hole and retighten?
Oh you mean on the intake not the valve cover right? |
08-24-2013, 01:39 AM | #4 |
Re: oil leak
Try pulling the bolts one at a time, cleaning the threads of the bolt and head with carb cleaner (use the straw off of carb cleaner), dob some thread sealer on the bolts and re assemble. It might save tou from having to pull the intake. If it still leaks you need new gaskets or something is cracked/ broken.
Posted via Mobile Device |
08-24-2013, 01:44 AM | #5 |
Re: oil leak
cool thanks guys. ill try it tomorrow. It may be time to pull it and paint it. Im doing a ground up in reverse
