Old 08-25-2013, 05:38 AM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Need help!runs out of fuel at hiwy speeds.
Originally Posted by PAPA KENT View Post
Thanks for your input.Do you know where you can purchase a sock without buying the entire sending unit?Since the rubber lines from the sending unit are hard as a rock i figure part of my problem might be there also so replacing the sock would be mandatory.
If they crack it will suck air instead if fuel. Idk if you can get the tank socks seperate but they keep large debris from clogging the lines. Check the filter at the carb too. Essentially the whole fuel delivery system would be back to new condition at that point. If the issue persists then the problem has to be elsewhere
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
