Old 08-25-2013, 08:45 AM   #1
builtbyKane
builtbyKane's Avatar
Re: 1970 C10 LWB "Blu"
Congrats on the drive. Sounds like after a little tinkering she'll be ready for years of loyalty. The carpet looks fantastic too. Any necessary tips you can share sinse you beat me to the carpet?
builtbyKane is offline   Reply With Quote
Old 08-25-2013, 05:52 PM   #2
NC_John
NC_John's Avatar
I lined up the carpet on the drivers side first- against the side of the cab, and had my wife hold it in place while I stretched it out to the other side to make sure it was over far enough. When I confirmed it was centered OK, I put the driver side door sill plate in to fix the carpet in place. Then I stretched it all the way over to the passenger side tightly and then put that door sill in. I found my seat bolt holes with a screwdriver from underneath the cab (which might be a problem on yours as low as it is). The mold of the carpet fit over the shape of the floor pretty good. It's a little wrinkled over the trans hump which is disappointing but its not too bad. Other than the gas pedal not fitting over the ball studs now there weren't any real issues.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
