Old 08-25-2013, 12:01 PM   #1
pound41
Opinions on Best Lift Kit
Looking to put a 4 in lift with rear springs and not blocks on my 71 K-5 Right now it has a 6inch rattle your teeth lift. It will go off road very little so I am looking for a somewhat smooth ride. Suggestions are appreciated
pound41 is offline   Reply With Quote
Old 08-25-2013, 01:23 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Opinions on Best Lift Kit
I've been very happy with the Skyjacker Softride 2" front springs on my K20. Excellent quality and a decent ride. They also make a 4" Softride kit that might be worth consideration.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 08-25-2013, 01:27 PM   #3
sboris
sboris's Avatar
Sounds like the one you have might be Rough Country, hence the name.. Can't suggest any as I've always had the low end ones. Very stiff... Interested in suggestions also
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 08-25-2013, 03:08 PM   #4
Prematuregrey
Prematuregrey's Avatar
You have a couple of options. First off what shocks are you running? Duals? I don't recommend dual shocks on anything that doesn't get a lot of abuse or pre-running. I've always been a big fan of Bilstein 5100 series shocks and just put a set of 5125's on my K-20 removing the dual Rancho setup it came with which were all bad, and that significantly helped the ride. Just make sure and spec out the correct lengths. The 5100's are slightly softer than the 5125's I believe.
Secondly, if you have a 6 inch all leaf spring lift, you could try and pull a couple leafs out of the spring packs which will lower you down some and soften it up a bit. This will be at a cost of load capacity so consider that when doing it. This can be fixed with an air bag overload setup or some Timbren bump stops fairly easily.
Poly bushings on your shackles will transfer bumps a lot more so you may want to try and stick with rubber at the cost of longevity.
All that aside, Superlift has always made a good product and I'm sure the Skyjacker Softride kits are built well and ride decent. Again, stay away from the dual shock setups and blocks under the leafs. You could also try and call up Deaver Spring Co. and have them walk you through a custom set of leafs.
Owner: Times Are Tough Toys
92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it.
89 Mercedes 560 SEL, Merdle. Wrecked
71 Chevy K20, Clifford, BB and 1 Tons
Prematuregrey is offline   Reply With Quote
Old 08-25-2013, 06:25 PM   #5
Bill72
Tuff Country EZ Ride.
Bill72 is offline   Reply With Quote
Old 08-25-2013, 07:26 PM   #6
Gene
Gene's Avatar
X2. I have an all spring 4 inch skyjacker softride and its on a swb. Not a bad ride at all.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 08-25-2013, 10:10 PM   #7
swamp rat
swamp rat's Avatar
All good info, heres another link:
http://67-72chevytrucks.com/vboard/s...d.php?t=436914
I also read another board stating that BDS was the best, i don't know personally but heres the link:
http://bds-suspension.com/product?ma...1&yr=1969-1972
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-26-2013, 10:25 PM   #8
70-K5
I recently ran a Tuff Country 4" lift that was a very good ride. Currently using a 6" Tuff Country spring set in a 89 K5. They have very low spring rates so depending on weight of your rig it might not give you enough lift.
70-K5 is offline   Reply With Quote
Old 08-27-2013, 05:47 AM   #9
For off the shelf pricing I like Tuff Country EZ-Rides. I've run them in 4" and 6" on Pickups,K/5s,and Suburbans,all with excellent results. I prefer the Rancho 9000RSX adjustable shocks because you can set them soft for the best ride,but can set them stiff if you load the back up or tow. I just use either the hardest of the softest. Not sure about the 7 positions between.
Old 08-27-2013, 09:03 AM   #10
pound41
Can someone with a 4inch lift give me a measurement from ground to bottom front tag
Old 08-27-2013, 10:54 AM   #11
70-K5
That's going to be a relative measurement as the size of tire will affect the measurement...
Better to measure from the center of the hub to the bottom of the wheel arch.
I have 4" Rancho springs on the front of my 70 K5, I can measure this evening.
Old 08-27-2013, 11:17 AM   #12
72 Green Monster
Just got in this forum and so far am impressed. In a somewhat response to your question on lifts. I have a 72 LWB with a 4'' Rancho lift, and also have a buddy that had a Blazer with a 4'' Rancho and both of them ride rougher than all get out. With my experience, I would probably try and stay away from Rancho. I too am still looking for a smoother ride while keeping the height. Hope this helps some, good luck.
72 Green Monster is offline   Reply With Quote
Old 08-27-2013, 04:06 PM   #13
srvivor71
srvivor71's Avatar
I put in Tuff Country EZ Ride 2" front lift / 3" rear earlier this summer. The new front leaf springs and shocks have made the ride so harsh I feel like it's going to bust the truck up (or my teeth). I hit a bump on the highway doing the speed limit (55) and am pretty sure I was airborne - with a very rough landing. When I got where I was going, I saw the battery had come off its tray. I think I may have to replace these front springs with something way less harsh before something breaks.
srvivor71 is offline   Reply With Quote
Old 08-27-2013, 05:01 PM   #14
SonoraBob
On my Jeep I used a number of brands. I bent quite a few. But BDS is the best in my opinion.
SonoraBob is offline   Reply With Quote
Old 08-27-2013, 07:58 PM   #15
CherokeeC10
CherokeeC10's Avatar
I have no experience on K5 lift kits but as far as shocks go I ran Bilstein 5125s w/ Skyjacker springs on a Jeep and it rode damn good. Bilsteins did awesome. Currently have 5150s on a Baja project and they are extemely smooth also.
And when he sees Saint Peter he will tell, "one more soldier reporting sir, for I have spent my time in hell".
CherokeeC10 is offline   Reply With Quote
Old 08-27-2013, 08:09 PM   #16
I've never had any lift kit ride that bad,and I've had about all of them...Rough Country,Burbank Spring,Rancho,even over-arched stock springs with added leafs. Not sure what shocks you are using or if they are correct for your lift. Are you by chance running stock length shocks? They say stock shocks work w/2" but I disagree. Not a 67-72,but on my '92 K3500 I've had the torsion bars twisted up to a 3" or so lift since back in '93-94. I went to replace the shocks 5 years ago and the stock length shocks wouldn't extend far enough to mount at full droop. I had to get longer shocks.
Tuff Country EZ-Rides are made to ride better and they do. They are not just a continuous arch that is higher. In the center the arch is much flatter than the outer ends. You ride in that flat area and not on a high arch that doesn't want to compress.
Old 08-27-2013, 08:14 PM   #17
BrianG
BrianG's Avatar
I have a 4" Skyjacker Softride with no blocks (replacement springs all the way around) I LOVE IT!!! very smooth ride. It is a K10 though, so I suppose there could be some difference being that your k5 is a little shorter wheelbase.
BrianG is offline   Reply With Quote
Old 08-27-2013, 09:57 PM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
They didn't work with my 2" front Softrides, but stock rear shocks work great up front with 2" springs.
- Mike -
RIP El Jay
Old 08-27-2013, 10:53 PM   #19
70-K5
26 3/4" from the center of the hub to the bottom of the wheel arch.
Old 08-28-2013, 08:10 AM   #20
BrianG
BrianG's Avatar
If you are asking because you are wondering what size tire that you can fit with a 4" lift. I'll tell you that I have a 4" Skyjacker Softride with 35" BFG Mud Terrain's. they fit okay, but when I really wheeled it, the tires did rub. I did end up cutting the corners of the fender arches a little. It looked really good actually. That gave me all the clearance that I needed for rough ridding sand dunes and that sort of thing. I'm in the middle of a restore on that truck and haven't decided what tire to go with. I don't think that I want to cut the fenders this time, and would really like the height of the 35's. they'll fit, I know that, and I don't plan on any serious wheeling once this restore is complete. Maybe a trip around the dunes once or twice but nothing too hard. Just thought I'd share and give my two cents.
Old 08-28-2013, 09:51 AM   #21
bowtie72
bowtie72's Avatar
Check out offroaddesign.com. I used their shackle flip kit . I love it and rides good.
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 08-28-2013, 02:35 PM   #22
They now make 10.50/35s. Of you mount those on 8" wheels you'll be good to go.
Old 08-28-2013, 04:49 PM   #23
BrianG
BrianG's Avatar
That would be great, except I really like my wheels. I'm pretty sure they are at least 10 inch. I had 35-12.50 - 15's on there. I'll have to check though. They are aftermarket rims. Thanks for the heads-up!
Old 08-28-2013, 04:56 PM   #24
srvivor71
srvivor71's Avatar
This was kit, offered by Suspension Connection, same as this one, except for 3" blocks in rear: http://www.suspensionconnection.com/...on/126103.html
Old 08-29-2013, 10:16 PM   #25
truck4man
truck4man's Avatar
I have the Skyjacker 4" softride with 12.50 33x15's on 10" rock crusher wheels and really like it.
truck4man is offline   Reply With Quote
