Old 08-25-2013, 09:00 AM   #1
58CHEVYAPACHE
Chassis numbers
I'm trying to find the numbers on a 1958 chevy 3100 they stamped into the frame that indicates which bed. What I'm hoping to find is 3134 which is fleet bed. Thanks
58CHEVYAPACHE is offline   Reply With Quote
Old 08-25-2013, 02:37 PM   #2
mr48chev
mr48chev's Avatar
Re: Chassis numbers
I'm not sure that there are numbers stamped in the frames on Task Force trucks but the Task Force guys will chime in on it when they see the thread.
There is info here on the truck side that might help
http://chevy.oldcarmanualproject.com...to/58index.htm
My ongoing truck projects:
Old 08-25-2013, 03:31 PM   #3
58CHEVYAPACHE
Re: Chassis numbers
Thanks I have that book but I need to buy the assembly manual. I can't find that one free online.
Old 08-25-2013, 08:01 PM   #4
OrrieG
OrrieG's Avatar
Re: Chassis numbers
one is stamped on top of frame rail just in front of steering box. if someone ground it off they is a second on top of the frame under the driver s step. to read it you need to make a rubbing, it was intended to be hard to get to so it could not be removed easily.
i think info you want is on the driver door data plate.
Old 08-25-2013, 08:40 PM   #5
mr48chev
mr48chev's Avatar
Re: Chassis numbers
I think that all you are going to find is the 3A which stands for 3100 series and short wheelbase. It really doesn't matter anyhow unless you are shooting for a 100 point restoration to show in national truck shows in quest of the big awards. Run what ever bed you want and so be it.
Old 08-25-2013, 09:31 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Chassis numbers
The vin may look like 3A58 X XXXXXX
the body id is in the last set of XXXXX numbers but unfortunately GM no longer has build sheets past early 70's.
3A pickup
58 year
X build factory
XXXXXX serial number
3A trucks could have been any of the below with a 31 prefix
02 Chassis-Cowl or School Bus
03 Chassis Cab
04 Stepside Pickup
05 Panel
06 Carryall ( Panel Rear doors)
09 Stake
12 Chassis-Cowl-Windsheild - like the Good Humor Man Truck
16 Carryall (Endgate)
34 Fleetside Pickup
42 Forward Control Chassis
45 Forward Control Step Van
53 Chassis-Cab - 4WD
54 Stepside Pickup - 4WD
55 Panel - 4WD
56 Carryall (Doors) - 4WD
66 Carryall ( Endgate) - 4WD
70 Sedan Delivery Panel
80 El Camino
84 Fleetside Pickup - 4WD
Some would be obvious to figure out but Pickups , Fleet or step, can only be determined by the last numbers in the serial number or a build sheet
