Old 08-25-2013, 11:03 AM   #1
blazer2007
slow rear window ?
Electric rear window kinda slow going up,is there some lube or grease spots I should maintain to ease the drag,maybe something in the window channels ?
blazer2007 is offline   Reply With Quote
Old 08-25-2013, 12:33 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: slow rear window ?
Usually its due to voltage lost in a corroded connection or worn/corroded switch. Lube will help but probably won't cure it.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-25-2013, 02:21 PM   #3
BaggedRanger
BaggedRanger's Avatar
could also be your motor is going bad. Mine would be really slow to go up and then I replaced it..
BaggedRanger is offline   Reply With Quote
Old 08-26-2013, 10:17 AM   #4
blazer2007
It was one I pick up last year so maybe I put too small a wire running to it,anyone know what gauge I should run
Old 08-28-2013, 03:08 PM   #5
I'd clean all connections and the tracks,first,before replacing a motor. Also,the lining on the track rots away so it doesn't slide well. These aren't cheap,but will make a big difference. They usually bind up once it's up to the curve...about 3/4s up.
Old 09-12-2013, 09:23 PM   #6
texastruckjunky
texastruckjunky's Avatar
I would use at least a 10 guage wire to run that far. The wire on mine is at least that or it could be an 8.
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
Old 09-23-2013, 05:34 PM   #7
Omar999
I changed the cable which connect the motor to regulator and performed a cleaning activities then put grease on regulator ...
results : moved more faster
Omar999 is offline   Reply With Quote
Old 09-24-2013, 08:19 AM   #8
1984 t type
Clean the tracks and check the rollers, they prob got dirty and started sliding instead of rolling and are now ground down and look more like a D instead of a O. That's how mines are at least.
1987 Buick Grand National
2018 Road Glide Special
1984 t type is offline   Reply With Quote
