Old 08-26-2013, 09:38 PM   #476
mud.man.rj
mud.man.rj's Avatar
Re: 69 GMC "Ol' Blue"
Some times decisions take care of themselves. Still only a bolt if you work slow at it can be fixed...or pay.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 08-26-2013, 10:42 PM   #477
mjensen
mjensen's Avatar
I'm really wanting to get the bolt out. I don't want to spend the money on the motor right now. I need to save money for the drivelines.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 08-26-2013, 11:01 PM   #478
mud.man.rj
mud.man.rj's Avatar
I have drilled many bolts out, but is slow precise work, can be done just need to know how. The thing is ...what is the rest of the engine like first. I would pull the pan and look at the bearings first before I maybe waste time on the crank.
5.0 4spd std.
7" lift w 35's.
Old 08-26-2013, 11:11 PM   #479
mjensen
mjensen's Avatar
I'm going to pull the pan and check everything out. I drained the oil the other day and it looked great. Clean and no water. It didn't make any funky noises or burn any oil when I pulled it out, but 4 yrs of sitting could be a different story
I've read on this forum that some people run without the bolt, but I'm not sure.
Mike
Old 08-27-2013, 12:43 AM   #480
mud.man.rj
mud.man.rj's Avatar
Well here is the thing before to many things like power steering were on the older 283/327 and some earlier 350 engines the balancer didn't even come with a bolt in it and crank not drilled and tapped for one. So not saying it would fall off but could install without the bolt and red lock tite the balancer to the crank shaft. it worked for years right from GM but as mentioned drilling is not hard just many small steps in drill size up at a time and lots of patience, plus of course drilling in the center. I would still rip the engine apart first or really if I was spending money build the 400 first, all comes down to personal choice, money and capability also. Good luck.
Rick/Mudman.
5.0 4spd std.
7" lift w 35's.
Old 08-27-2013, 06:04 PM   #481
7dee2
7dee2's Avatar
Mike, just got caught up on your thread.
The broken crank bolt can be removed with an easy out that is the correct size with some heat and patience (make sure you drill it straight) . GM put the big bolt, lock washer and large flat washer to keep the balancer from coming loose. I had a friend that lost his balancer going down the road and did extensive damage to his corvette. Don't run without it, bad idea could cause you some heartache.
I like the idea of running the 327 while you build the 400 the way you want. Only because I think your truck will be under powered with the stock 327 but this way you make that decision after trying it. Also if you know the history of the 327 and just got a little smoke on startup that is the valve guides starting to wear out and is an easy fix just install umbrella seals. Read up on how to adjust the valve lash. My guess is it's a hydraulic cam and they are the easiest to adjust.
You do need to pull the pan to repair the rear main seal leak. Make sure you do this correctly or you will end up doing it all over. I would also try firing the engine asap and you will know what you have. Make your repairs and prior to paint mock it up in the frame and run it. Fix the leaks adjust the valves and when your satisfied paint it.
My 2 cents.
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 09-01-2013, 02:50 PM   #482
cmabolt
cmabolt's Avatar
Hey Mike! Nice build. Figured I would slide on over and check it since I can't work on mine for a couple more weeks. Tough news about the crank bolt. This kinda stuff is exactly why just put in an LS rather than mess with my 350.
a 40 year old small block has seen too many wrenches.
Frames turned out great as well. Keep it up.
Chris
Project Reno
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636
Easier to beg forgiveness than ask permission!
cmabolt is offline   Reply With Quote
Old 09-01-2013, 04:33 PM   #483
mjensen
mjensen's Avatar
Rick/Mudman.
I think that's some pretty solid advise. Thanks!
My 2 cents.
Thanks for the 2 cents Brett :-) I'm going to need all I can get to figure out what to do.
Chris
Project Reno
Thanks for stopping by Chris and thanks for the compliments. This project has now been derailed until I figure out what to do about this engine. I did clean all the old grease off the block yesterday just so I feel like progress is being made.
Mike
Old 09-05-2013, 10:31 PM   #484
mjensen
mjensen's Avatar
So, I'm thinking about a new engine option. I can get a Blueprint Engines fully dressed 383 complete with a 750 cfm carb and HEI distributor for $3,600 shipped. It is dyno'd at 330 hp/385 Ft lbs of torque. The monster 430/450 would end up $1,000 more fully dressed. I'm starting to think this may be the direction I end up going. Anybody watching the thread have any thoughts on this?
Mike
Old 09-06-2013, 12:24 AM   #485
cmabolt
cmabolt's Avatar
I say go with the 383 for the torque or say screw it and go LS. Of course I'm a little biased.
Chris
Old 09-07-2013, 10:18 AM   #486
mjensen
mjensen's Avatar
I would go LS if I didn't want to keep my old 4 speed. I'm a little weird that way I still need to call my local engine shop to get his opinion and options, but I'm really leaning towards the 383 now. All I need to do is sell my motorcycle and I'm on it!
Mike
Old 09-07-2013, 01:23 PM   #487
mud.man.rj
mud.man.rj's Avatar
All I can say more is better, trucks aren't all that light, I big block everything myself, just love torque.
5.0 4spd std.
7" lift w 35's.
Old 09-12-2013, 11:05 PM   #488
swamp rat
swamp rat's Avatar
Originally Posted by mjensen View Post
I received my spindle nuts today, so I tore down the driver's side again and replaced the nuts, then buttoned up the passenger side. Front end is all but done!!! I am so pleased with how it turned out.
Attachment 1139266
Where did you get the spindle nuts at? and were they the 3/8's or the 7/16's?
You have made some great progress on this truck!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-12-2013, 11:17 PM   #489
mjensen
mjensen's Avatar
Thanks! I hope to do some minimal things this weekend. I'm going to get my trans/splitter/bell housing sealed up and bolted together. Possibly even mount the tcase
The spindle nuts came from my favorite place to order items from...Rockauto . Looking at the specs, they are 3/8".
Mike
Old 09-12-2013, 11:44 PM   #490
swamp rat
swamp rat's Avatar
Rock auto to the rescue again! I'm gonna run to the hardware store and see if they have this kind of nut, if not then i'll order some. Thanks!
Found out too that the Barrel taper bearings are no longer made, all are converting to tapered roller, thanks for the help there too, it gets kinda frustrating when you spend hours searching for answers on the net.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-12-2013, 11:53 PM   #491
mjensen
mjensen's Avatar
Glad I could help! I would think that any Napa or the like should have those nuts too, but I was ordering other stuff so I just threw them on the order.
I know what you mean about hours researching. I have spent the last 2 weeks obsessing and researching what I'm going to do for the powerplant. I'm now leaning towards just building my own. Seems like going with the cheaper Blueprint engine has been real hit or miss with others on this forum and others.
Mike
Old 09-13-2013, 12:33 AM   #492
swamp rat
swamp rat's Avatar
I cant find them in Rock auto..
I have hopes on a 383 stroker that will run on mid grade, but right now the bank account says to just run what ya got, especially if its still running strong.. I rebuilt my engine back in 96 went with a 30 over, RV cam and some other standard stuff keeping in mind that trucks need torque, and the operating rpm range which i drive ect. The machine shop that did the balancing of my rotating assy said with all the parts he estimated about 335 hp, nothing too wild but that's fine, i don't want wild, but i haven't pulled a heavy trailer since then ether so when the time comes i figure it will be because i'm not happy with the power pulling a trailer or heavy load up the pass..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-13-2013, 12:35 AM   #493
swamp rat
swamp rat's Avatar
Oh, Blue printing is a lot of labor hours working up a piece of paper documenting all the particulars., I think its more important to put that money into having a machine shop balance the rotating assembly and buying good parts.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-13-2013, 09:45 AM   #494
mjensen
mjensen's Avatar
What can't you find on Rockauto? I really wish I could have just slapped my 327 back in. You would think the thing would have been a dog, but the gearing was so low that it actually towed very well. But, you know, it's a damn shame to have to upgrade
The company is called "Blueprint Engines" which is where I was looking at picking up a fully dressed 383 for $3,600 shipped. That seemed like a really good deal at the time, but I'm just not willing to roll the dice on whether they built mine correctly. They use all remanufactured parts to keep the costs down, which would be fine if it were a local shop that I could just tow it to and tell them it broke. I'm now on the path of determining what I'm going to build. I'm back to finishing my 400, or build a 383. The only real advantage I have with the 400 is that the block has already been bored 30 over and I have the pistons and rods. I'm still unsure about the crank, as the journals have surface rust that I'm not sure can be polished out. I still plan on calling my local shop to get their opinion, but I've been spending weeks researching so that I know what questions I should ask.
Mike
Old 09-13-2013, 07:33 PM   #495
swamp rat
swamp rat's Avatar
I couldn't find the spindle prevailing loc nuts, 3/8 NF, 6 per side.... But that's ok because i found them at my local hardware store for $0.40 each today.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-13-2013, 08:36 PM   #496
mjensen
mjensen's Avatar
Awesome! I'm glad you found what you needed.
Mike
Old 09-15-2013, 07:07 PM   #497
mjensen
mjensen's Avatar
Got a little done today. Engine and Tranny are back in. Engine will need to come out again, but the trans is good to go.
Mike
Old 09-15-2013, 10:29 PM   #498
swamp rat
swamp rat's Avatar
Cool!
BTW: You didn't say what brand the splitter is in your prior post, i'd like to look it up.
http://67-72chevytrucks.com/vboard/s...&postcount=243
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-15-2013, 10:33 PM   #499
mjensen
mjensen's Avatar
Cool!
Thanks! It's called a Ranger III and made by Advanced Adapters. They have an overdrive and under drive model. This one will give me the same final drive ratio as having a 5 speed in it.
Mike
Old 09-15-2013, 10:44 PM   #500
mjensen
mjensen's Avatar
Well, I decided to mount the transfer case...when I was tightening up around the input shaft...crack went the rear bearing plate. Not cool! Apparently with the new input shaft bearing, I should have double checked that.
Mike
