Old 08-27-2013, 05:10 PM   #1
willett
Another Day, Another Dollar
willett's Avatar
Exclamation Wtf??
Hey again,
Did a cab swap on my '78 k20. I re-used my old harness.
Now when I pull the headlight switch out my gas gauge drops to below empty and none of the cluster backlights illuminate.
I'm guessing I'm having some sort of ground issue here but I could use some direction on where to start.
Is there a master cluster ground wire?
My other interior lights are working, I still need to pick up a new cab ground strap. To be honest I'm not really sure how the cab is getting negiyie feed but since my other interior lights are working I don't think the the root of the problem.
Ps. Same cluster and same wiring harness that was in my old cab.
Spencer
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 08-27-2013, 06:25 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Wtf??
If it worked in the other cab it should work in this one, I'd start with the above...... Sometimes there's no rhyme nor reason when it comes to electrical.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 08-27-2013, 06:59 PM   #3
07XCSBZ71
07XCSBZ71's Avatar
Re: Wtf??
I had one doing the same thing, turned out to be a bad headlight switch.
07XCSBZ71 is offline   Reply With Quote
Old 08-27-2013, 08:33 PM   #4
willett
willett's Avatar
Re: Wtf??
I'll pick up a strap and a headlight switch tomorrow
Old 08-27-2013, 08:34 PM   #5
willett
willett's Avatar
Re: Wtf??
I did put in the headlight switch from the new cab and the new cab used to be in a propane truck so the fuel gauge was NFG anyways. Hmm...
Old 08-27-2013, 08:41 PM   #6
mrolds88
Re: Wtf??
Did you maybe miss a ground that ties in at the ground "spider"?
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 08-27-2013, 08:54 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Wtf??
there is a spot about a foot from the cluster plug they all go down to one
should be easy to find , if you want to see it look in my 78 below ,when I did the cluster swap
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-27-2013, 09:43 PM   #8
MalibuSSwagon
Re: Wtf??
The printed circuits on the gauges wear out from age, and can cross circuits at the connector. I'd check that too, if you have contacts lifting or the layers are separating you will need to replace it.
MalibuSSwagon is offline   Reply With Quote
Old 08-27-2013, 11:13 PM   #9
willett
willett's Avatar
Re: Wtf??
Do they all just go into a single spade? Any idea off the top of your head if it's a solid black wire or not?
Ed.
I just remembered that I have a harness from a '73 laying around, I'll take a gander at it in the morning.
Old 08-28-2013, 06:47 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Wtf??
crazy glue will reattach them paths to the board
the radio heater anything grounded there seems to go to one "crimp"
and it carries as one wire from there
John
Old 08-28-2013, 01:13 PM   #11
willett
willett's Avatar
Re: Wtf??
Radio heater? What the heck is that?
Old 08-28-2013, 02:34 PM   #12
mrolds88
Re: Wtf??
I think he forgot a comma.
93 K2500 xcab 6.5TD
Old 08-28-2013, 04:34 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Wtf??
yup I did , can't remember where they all go but I read here it was good to add grounds, I did, I was swapping clusters, and needed to add even another ground,anyway for the small gas gauge.
it stopped my gauge from bouncing too.
find a black wire on the cluster plug follow it back and you will find it for sure!
John
Old 08-29-2013, 09:51 AM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Wtf??
here it is
John
Old 08-29-2013, 03:15 PM   #15
willett
willett's Avatar
Re: Wtf??
thanks bro!
I haven't had any time to mess with it since I made this thread and I'm heading out of town this weekend, but hopefully by Tuesday I'll have er' back in the shop. I have a feeling that there's a ground dangling somewhere.
On a completely unrelated topic Motornut, how did you lose 3 trucks while parked?
Old 08-29-2013, 04:06 PM   #16
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Wtf??
thanks bro!
I didn't lose them lol they were "close" to where i left them,or where the drunks left em
now i just buy shorter trucks...seems to be working!
the 78 and 87 were hit parked at work
the 88 in front of the house
John
Old 08-29-2013, 06:20 PM   #17
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: Wtf??
naturally,,, smaller target, harder to hit ! makes since to me.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 08-29-2013, 10:16 PM   #18
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Wtf??
yup sure is smaller lol so is my GA he missed behind it
(next morning,78 Jimmys further up)
and now i got this great pic when somebody wants to know where the door wires go lol
John
Old 09-04-2013, 04:12 PM   #19
willett
willett's Avatar
Re: Wtf??
Finally got some more time to mess around with it.
Attached a body ground - nothing
Tried a headlight switch - no difference
Started monkeying with the cluster harness - the plug into the back of the cluster wasn't in all the way. D'oh!!
Problem solved!
Now I have to find the .69 amp draw. How the heck do I pull glass fuses without breaking them?!?!
Old 09-04-2013, 06:11 PM   #20
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Wtf??
Problem solved!
cool,small flat head from the end
John
Old 09-04-2013, 11:03 PM   #21
willett
willett's Avatar
Re: Wtf??
That was the first thing I tried, but some of them are seized in there and end up breaking in half if I can get an end to budge. Guess I just gotta take it sloooooooooow
Old 09-04-2013, 11:23 PM   #22
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Wtf??
changing them old ones might be a good thing anyway
20s were hard to find at a Canadian tire store,was surprised at that
all kinds of newer, but a couple of mixed packs with 1 -20
John
Old 09-04-2013, 11:27 PM   #23
willett
willett's Avatar
Re: Wtf??
Lol I shredded the 20a radio fuse today and all I could find was a 15 and a 30, I went with the 15. Should be good, I run a power amp anyways
Old 09-05-2013, 09:12 PM   #24
willett
willett's Avatar
Re: Wtf??
So the under-the-dash light draws about .67 amps :|
I knew the dome light wasn't connected but I forgot about that one. What I did learn is that the constant power on my tach draws 3-4 ma though for some reason. :s
