Old 12-08-2012, 04:10 AM   #151
Chevette
Chevette's Avatar
Re: 56 step/C5/C6 Z06 BBC
Originally Posted by made2drag View Post
amazing work
Thanks, made2drag.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 01-06-2013, 02:31 PM   #152
shadow1967
shadow1967's Avatar
Chevette,
Thinking of my next project dad's 38.
Could I get the measurement from arm bolt to arm bolt on th rear cradle?
Then the measurement from out side to out side of tire?
Then the offset of the rims you have? 19x12's right?
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 01-06-2013, 07:39 PM   #153
R.A.D
nice things going on here
R.A.D is offline   Reply With Quote
Old 01-06-2013, 08:02 PM   #154
Chevette
Chevette's Avatar
Originally Posted by shadow1967 View Post
Chevette,
Hey, how's it going? My wheels are 19" X 12" the tires are 325/30/19 and my wheel backspace is 8.0" offset is 4.0". See pic for the other measurements.
Hope this helps. If the track is too wide for you, have a look at the Cadillac. It's very similar to the Corvette (in fact it's built in the Corvette plant). I don't know the spec's on the Caddy, but it might be narrower. Anyway, good luck.
56 Chevy PU
Old 01-06-2013, 09:24 PM   #155
shadow1967
shadow1967's Avatar
Thanks,
Mike
Old 01-07-2013, 01:12 PM   #156
1955GMC
Nice work. I'll be waiting to see where this build goes. Real "out of the box thinking" here
1955GMC is offline   Reply With Quote
Old 01-18-2013, 08:07 AM   #157
R.A.D
x2
Old 01-19-2013, 01:16 PM   #158
shadow1967
shadow1967's Avatar
Sorry for being a pain But DAD and I have another measurement question.
What is the height difference between the cradle mounts(front to rear)?
Thanks in advance,
Mike
Old 01-19-2013, 02:40 PM   #159
Chevette
Chevette's Avatar
Thanks in advance,
Mike
With the cross member sitting level, front to back (at the base) there is a 2" difference at the mounting surface(front being 2" lower than the back). I have mine set up so the intake manifold will sit level when the engine is attached to the bell housing/torque tube, as I'm not using an LS. I assume you can change the angle of the torque tube to level when using an LS with a level manifold.
56 Chevy PU
Old 01-19-2013, 02:42 PM   #160
Chevette
Chevette's Avatar
Thanks in advance,
Mike
It should be noted that I have changed the angle of the cross member since that pic was taken.
56 Chevy PU
Old 01-21-2013, 10:12 PM   #161
Chevette
Chevette's Avatar
Playin' around with my new pipe bender. Works well.
56 Chevy PU
Old 08-27-2013, 10:04 PM   #162
Chevette
Chevette's Avatar
Finding the time and enthusiasm has been a struggle lately. I did manage to get the radiator mounted and the fit is good. It's almost time to disassemble the chassis and get it coated.
56 Chevy PU
Old 08-28-2013, 10:48 AM   #163
Kim57
Kim57's Avatar
Looking good.
Keep the pics coming.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-28-2013, 04:35 PM   #164
reinmeister1951
That is one Funky looking radiator. Looking good.
Doug
48 chev LWB pickup 350 turbo400 tri power
48 GMC S10 350 700R4
48 che 5 window 2012 Camero suspension & power train
reinmeister1951 is offline   Reply With Quote
Old 08-28-2013, 08:24 PM   #165
Chevette
Chevette's Avatar
It's from one of Jimmy Johnson's race cars, but it was never used. It is very high capacity. How's the hot rod coming along?
56 Chevy PU
Old 08-28-2013, 08:26 PM   #166
Chevette
Chevette's Avatar
Originally Posted by Kim57 View Post
Looking good.
Kim
Thanks Kim. I'll be trying to get some time in about two weeks to work on it some more. How are things with you?
56 Chevy PU
Old 08-29-2013, 09:36 PM   #167
shadow1967
shadow1967's Avatar
Glad to see you at it again. More pics of that funky radiator.
Old 08-30-2013, 08:00 AM   #168
xpickup
xpickup's Avatar
Chevette, good to see you back at it. Keep the pictures flowing while you are working on it. You know how we all like pictures.
Shannon
xpickup is offline   Reply With Quote
Old 08-30-2013, 08:44 PM   #169
Chevette
Chevette's Avatar
Thanks Shadow. I'll post a couple more "rad" pics in the next few days.
56 Chevy PU
Old 08-31-2013, 01:33 AM   #170
mud.man.rj
mud.man.rj's Avatar
I am always amazed at the quality and quantity of this build, very interesting, keep it coming, like your way of thinking, no in the box here.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 09-01-2013, 08:09 PM   #171
mr incredible
mr incredible's Avatar
WOW ! what a great build. just read the whole thread. i'll be glued the rest of the way.
USN RETIRED
there are two things you don't need in the navy. that's a wife and a pick up truck. cause when your out to sea someone else is using them
mr incredible is offline   Reply With Quote
Old 09-06-2013, 02:39 PM   #172
Chevette
Chevette's Avatar
Thanks for the kind words, mudman.
Much appreciated.
56 Chevy PU
Old 09-06-2013, 02:41 PM   #173
Chevette
Chevette's Avatar
Thanks Mr Incredible.
56 Chevy PU
Old 09-14-2013, 09:58 PM   #174
Chevette
Chevette's Avatar
Here's another pic of the radiator and one of the crown removal.
56 Chevy PU
Old 09-14-2013, 10:02 PM   #175
mr incredible
Thats taking shape very nice
USN RETIRED
