Old 08-31-2013, 08:59 PM   #1
1972_Buford
Power steering hose routing and fitment issues... experience or comments appreciated
So I found a thread that shows two different ways to route power steering hoses.
http://67-72chevytrucks.com/vboard/s...g+hose+routing
Now, mine routes by going under the power steering pump instead of coming up over the pump in between the alternator.
Now, both ends of the hose are male ends and are different sizes so they only go in one way. I ordered this from autozone
http://contentinfo.autozone.com/znet...70917/image/2/
as it had both male ends on the hose. Now, just from the picture I cannot tell if it bends the same as the one as I have but I assume so (first problem). I get the hose in the mail. Several weeks go by before I can install it due to washer machine breaking and a/c going on the fritz (AZ heat). So I get to it today and find the routing is wrong.
So I go online and find this
http://contentinfo.autozone.com/znet...71065/image/2/
Now just looking at the photo it looks like the routing is correct or closer to what I have. But, the ends are different as one is a female fitting. In the photo it looks like it comes with an adapter/coupler.
If I try to is the hose I have there are many issues as it comes very close to headers and it gets bound up and all twisted (hose). And No I will not zip tie it. Zip ties become very brittle in AZ under the hood and tend to fail.
So my question is: Is adapter there so I can turn it into a male fitting? Am I missing something?
Any help appreciated
-B
1972_Buford is offline   Reply With Quote
Old 08-31-2013, 09:18 PM   #2
franken
Re: Power steering hose routing and fitment issues... experience or comments apprecia
You're not missing anything... I have no idea why the new hose has a female fitting
I have the same hose as in the 3rd pic and haven't tried to install it, but have my doubts about if it will work. My hoses are wrong so I can't compare old to new.
Try the Napa store for a male female flare coupling. I can snap a pic and email it if you want.
Old 08-31-2013, 09:33 PM   #3
1972_Buford
It looks like it comes with one (coupler) in that third photo. Does it not?
Old 08-31-2013, 10:17 PM   #4
MidLifer
MidLifer's Avatar
If not a zip tie how about a hose clamp? Should hold up better in AZ.
MidLifer is offline   Reply With Quote
Old 08-31-2013, 11:53 PM   #5
1972_Buford
I would rather route it like it was originally. I dont like "making" things work nowadays. I want it to be the same as that how it was working before. I would think someone here would have run into this problem on whether or not that hose comes with the coupler and turns it into a male version.
Old 09-01-2013, 12:42 AM   #6
leddzepp
Moderator
leddzepp's Avatar
Try the one that looks like it will route properly (looks like it has an adapter). Whichever one works, go with it and return the one that doesn't.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-01-2013, 01:15 AM   #7
jcd9730
jcd9730's Avatar
I replaced these a couple months ago when I did the PS pump. You use this one:
And the included adapter goes on the pump end of the hose. Warning- It will be a huge pain to put in, but it seemed easier to screw the pump end about halfway in and then thread the other end into the box. Still annoying to do though.
Josh
72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs...
jcd9730 is offline   Reply With Quote
Old 09-01-2013, 03:30 AM   #8
1972_Buford
If the adapter goes into the pump and not the gear box the. It wont work. Looking at the photo, the way the pipes are bent it would need to go into the gearbox to be run correctly
Old 09-01-2013, 03:34 AM   #9
jcd9730
jcd9730's Avatar
Nope. Adapter goes into the pump. You can't really route the hose the other way because it won't fit under the inner fender. And even if you got did make that work, I've no idea how you would make the other end reach the right spot on the pump
Josh
Old 09-01-2013, 03:40 AM   #10
1972_Buford
Hmm maybe i am just looking at the photo wrong. Actually the hose i did get i thought would fit too so just goes to show i am looking at them wrong. Going to nut a gear box rebuild kit tomorrow too. Well see how that goes. Thanks for the reply. I will update this for future reference.
Old 09-01-2013, 03:41 AM   #11
jcd9730
jcd9730's Avatar
If you have trouble I can take pics if you need
Josh
Old 09-01-2013, 03:43 AM   #12
1972_Buford
Great thanks. I will let you know but i can kinda see how that will workout too
