Old 09-01-2013, 01:10 PM   #1
Hparker619
needing help with wiring a column
i've got a 1964 but i put a 1969 column in it & I need to know what wire to hook into the old plug since it want hook right back up ........ have any of you guy's changed column's and ran into the problem ?
Hparker619 is offline   Reply With Quote
Old 09-01-2013, 01:15 PM   #2
tincan1966
tincan1966's Avatar
Re: needing help with wiring a column
The wire colors should be the same.
But if you do not want to cut and splice wires, you can get and adapter harness connector that will mate the flat plug in fro the '69 column to the semi circle of the '64
here's the breakdown:
On the 1969 column:
White from brake light switch to column
yellow left rear turn/stop lamp
green right rear turn/stop lamp
dk blue right front turn lamp
lt blue left front turn lamp
black horn(grounds relay)
purple 12v+ from turn signal flasher to t/s switch
brown 12V+ from hazard flasher to t/s switch(you will have to add a flasher for this to work)
Should be the same on the '64 column with the exception of the brown hazard flasher wire.
tincan1966 is offline   Reply With Quote
Old 09-01-2013, 08:44 PM   #3
Hparker619
That's what i needed to know THANK YOU Very Much
On the 1969 column:
Old 09-02-2013, 08:34 PM   #4
Hparker619
I got some of them working but it's not right
64 wires
dark blue
Lt blue
green
yellow
white
black
purple
68 column not 69
purple
black Lt blue line
black yellow line
brown
green yellow line
black white line
blue
i can get the tall light's to come on & when you hit the brakes the light want light up like it should in the back BUT when i turn the head light switch off the brakes light up ??????????????
On the 1969 column:
Old 09-03-2013, 01:34 AM   #5
jtrichard
bad ground in rear most likely
jtrichard is offline   Reply With Quote
Old 09-03-2013, 07:13 AM   #6
tincan1966
tincan1966's Avatar
X2 the most important thing you can do is make sure the tail lights are grounded good.
Try adding a 10 ga wire from the frame to the rear cross sill of the bed. You may have to remove the light assemblies and add a ground wire directly to them and then connect them to the frame, as well.
Old 09-04-2013, 03:28 PM   #7
Hparker619
Thank's guy's it was the Ground & the tail light the didn't match one was grounding the other out plus after looking at that picture i had to lower it more
