Old 09-02-2013, 08:13 AM   #1
Jake Wade
Jake Wade's Avatar
Rubberized undercoating on new gas tank
I am going to get a new gas tank for my 85. I will be doing away with the plastic shield that's under there. I would like to coat the tank with something and thought about 3M rubberized undercoating.
Will that work OK?
Jake Wade is offline   Reply With Quote
Old 09-02-2013, 09:15 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Rubberized undercoating on new gas tank
I have done this myself. Its been done over three years and my truck is pretty well a garage queen but its been great so far.. I left my plastic shield on but I sprayed the entire tank to rust proof it. It looks good and hoses off well
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-02-2013, 09:16 AM   #3
Jake Wade
Jake Wade's Avatar
Thanks!
Old 09-02-2013, 10:14 AM   #4
bigd65
bigd65's Avatar
I would think water could get under it nd be stuck there and rust out over time. The shields have drains on them that lets the water drain out
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 09-02-2013, 11:04 AM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
If you're getting water under the undercoating you have other issues besides possible rust developing.
Both new tanks I put under mine we cleaned and sprayed with undercoating. Just something to cover the ugly metal. If I recall the tanks were raw basically with a greasy coating of some sort on the outside. We thought about just using rattle can paint but decided undercoating would be a little tougher in the long run. My shields are in place though as well.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 09-02-2013, 03:06 PM   #6
tucsonjwt
I would leave the shields on. They will take a scrape if you run over something and possibly save puncture/damage to the tank. I saw some shields at the pick and pull recently that were the full length of the tank and they seem to have done the job. I never saw full length shields before but they looked very practical.
tucsonjwt is offline   Reply With Quote
Old 09-02-2013, 05:14 PM   #7
old Rusty C10
MY CUCV has the full length shield I imagine it was some kind of option.... I bet Keith Seymour would know for sure
Bob
I hate cancer!!
Old 09-02-2013, 07:11 PM   #8
king-918
king-918's Avatar
Will that work OK?
Hell I coated my whole frame in that stuff
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 09-02-2013, 07:53 PM   #9
Jake Wade
Jake Wade's Avatar
I had rather leave them off as I found a lot of debris trapped between the tank and shield which led to tank rot.
Old 09-02-2013, 08:29 PM   #10
78 Bonanza
The 3M undercoating is junk if you plan on driving the truck alot. I would go with Eastwood rust encapsulator (paint on 1 qt. can) and then some other higher end coating over that to protect the tank. We've tried rust bullet but it didn't hold up well. And we have had so many redo's with the 3M that we shy away from anything they offer now. The shield traps some junk but is there to prevent punctures, etc. from road hazards. With a good coating of a base and a undercoating you shouldn't have to worry about the small stuff that gets trapped in there. Just check ratings on whatever you buy as every company, including Eastwood, sells some stinkers. In our restoration shop we use a variety of different chemicals from a wide variety of makers. Just takes some homework. And remember to do proper prep. work, put on a nice even coat and let it cure all the way before you put the tank back on or you will have peeling and another rusted out tank (even without the shield). Hope this helps.
78 Bonanza is offline   Reply With Quote
Old 09-02-2013, 08:30 PM   #11
old Rusty C10
I pressure wash the bottoms of my trucks up here in the salt belt several times a year.. that eliminates the debris.... junk accumulates under the straps and mounts too
Bob
I hate cancer!!
Old 09-02-2013, 09:25 PM   #12
v30crewcab
v30crewcab's Avatar
what about spraying them with bedliner, a little tougher than the rubber undercoat, would protect it from rust better as well.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-02-2013, 09:39 PM   #13
maxxxy
maxxxy's Avatar
I used bedliner on my tank. It looked really good but the first time I spilled gas on it, it ate through the paint.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
