Re: SBC discussion
Yeah I don't plan on high RPMs but I do like that low end power for hauling since that's what I bought the truck for to begin with. Now on the built 305 paul mentioned be worth it? I thought bout vortec heads, bored .030" roller valve train and since it shares the 350s crank and rods get a stroker kit from a 350. I know it's common sense smaller engine will get better MPG but would it even be worth sticking with a small bore 305 or just build a 350 the same way? What MPG difference could I expect between the 2? I do lke that my truck can get over 20 on the hwy even without the 700r4's O/D. Could I still get some more efficient 350 heads from the junkyard?
#2 | |
Re: SBC discussion
A tpi 383 I would recommend vortec heads and nothing less to get the full benefit. That should be about 30ftlb/hp above the 350 with comparable setups, good if you really need the torque to tow. Me personally if I was concerned about gas mileage and being able to tow normal truck loads a 305 and 350 won't be a whole bunch different other than having extra power if I need it, and when is that ever bad? It's not hard finding a low mile LB9 305 that just needs a quick refresh. You can get one with the tpi and you can swap the cam and throw in TBI heads for cheap. There's a lot of things you can do, it all depends on what you want to do with the truck expectations and what you need it to do, of your hauling semis across the country maybe you need a big block? ![]() Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
