Old 09-02-2013, 05:41 PM   #1
1slo_camaro
Headlights....
Whats everyone doing? just buying stock silverstar sylvanias.... I am thinking about picking up a conversion set from ebay..... anybody have any history with them?
http://www.ebay.com/itm/7-ROUND-H602...027bae&vxp=mtr
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 09-02-2013, 06:17 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Headlights....
A lot of people like them ESP after doing relays
Those projector look a likes are garbage though. Nothing like real projectors at all
Normal conversions will work fine, hella e code are the shiznit to get though
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-02-2013, 06:19 PM   #3
1slo_camaro
Re: Headlights....
what do you mean after doing relays?
Old 09-02-2013, 06:26 PM   #4
INSIDIOUS '86
Re: Headlights....
Basicly when you turn your headlights on the power goes through all the wiring and headlight switch and back to the headlights. Voltage drops quite a bit through all that which makes the lights dimmer. Adding relays bypasses all that. You draw power right from the relay which is hooked direct to the battery. Makes the lights much brighter
Old 09-02-2013, 06:27 PM   #5
1slo_camaro
Re: Headlights....
OOOOO Gotcha, i never thought of that, or seen it anywhere. Kinda good idea thanks!!!
Old 09-02-2013, 08:02 PM   #6
INSIDIOUS '86
Re: Headlights....
Search it on the forum here. It's pretty common now
Old 09-02-2013, 08:31 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Headlights....
there are different silverstars I run the better ones on my CUCV and the lighting is much better
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-02-2013, 09:48 PM   #8
1slo_camaro
Re: Headlights....
i ran the sylvania silverstars in my first truck and they were great, but since i have ran HIDs in my jeep and my neon i dont want to ever be without them again haha
Old 09-02-2013, 11:13 PM   #9
bilfman
bilfman's Avatar
Re: Headlights....
I bought the Hella's from amazon.
HELLA 002395301 Vision Plus 176mm High/Low Beam... HELLA 002395301 Vision Plus 176mm High/Low Beam...
Love them. They are a little flatter on the front of the bulb then stock sealers, but they still look fine. The lenses fit perfectly and they will work with stock switch, but as previous posters said I would go with relays. 2 relays cost $5 at any local electronic supplier. Also Amazon can supply them too if you want to bundle the order. Remember to get 2 relays, 1 for high beam and 1 for low beam.
2 reasons for installing relays, 1 better voltage to the lights means a brighter bulb and 2 these bulbs draw more amperage, while they will work just plugging them in, eventually your stock light switch will die. Probably after a couple years.
A helpful tip for installing relays. Get the 2 light sockets and wire ( cut as much as you can get) from a wrecked truck. This way you can just use spade connectors from you existing sockets to 'signal the relay' and then use the cut sockets from the wrecker to tap into the relay and plug into your new lights. This way you don't have to cut anything in your existing headlight setup and you can go back to stock in minutes if you want.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 09-02-2013, 11:15 PM   #10
1slo_camaro
Re: Headlights....
The only thing i dont like is I am trying to get away from the sealed beam. and i want to put a set of HIDs in the truck
Old 09-02-2013, 11:18 PM   #11
bilfman
bilfman's Avatar
Re: Headlights....
The amazon are not sealed beams, They use a 9003 bulb, you can put any style of 9003 in there.
Old 09-02-2013, 11:19 PM   #12
1slo_camaro
Re: Headlights....
ooooo ok my fault. when i first checked them out they looked sealed
