Anybody running a 32/36 Weber on a 250?
Still trying to decide on a carb/intake setup for this 250, then I found a complete conversion kit for inline 6 engines that will use an adapter and the stock intake manifold. Seems like a pretty cheap way to upgrade the carb. Will a small 2 barrel weber be a substantial improvement over a stock old Rochester 1bbl? I thought with very minor mods such as elec ignition, 194 head, headers, rv cam, and a weber it should run a little better than stock. Thanks.
![]() Join Date: Oct 2012
Re: Anybody running a 32/36 Weber on a 250?
The most awesome upgrade for an I6. Love my weber 32/36 and 18+ mpg
Posted via Mobile Device |
#3 | |
![]() Join Date: Mar 2013
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#5 | |
Not really, from what I know. If you changed it to a lump port head and threw in some oversize valves(1.94 or 1.84 intake and 1.60 exhaust) then you would see a big difference, but the stock 250 head would be fine to. A good book on that subject would be the Chevrolet Inline 6 cylinder Power Manual, it will give you a good list of parts for what you are doing.
I have the 2nd edition of that book coming in the mail, hope it covers most of what the 1st edition does, thanks.
#8 | |
Stock rebuilt motor...thought it was a 230, turns out its a 71 olds 250...running the HEI and factory manifolds with factory single exhaust and a single Thrush. Runs like a Scalded Raped Ape-Dog where smooth and reliable is concerned.....can't hardly believe how much better HEI and Weber 32/36 is than stock. It won't put yer spine in the seat back like an 8 but I don't get passed by Hondas runnin fart cans anymore either....and I get better mileage than my wife's jeep with my 3.73 gears and a 3 speed and 3640 lbs with a half tank of fuel (I know cause I weighed it!) Truck throws itself around with that 71 Olds stock 250 like you wouldn't believe.....ran it as high as 95 mph, still got power and guts to spare...tweakin the secondary now for hill climbing power with good success. All pushing 18 to 19 mpg range. Very awesome set up for mileage, slight power increases and exceptional reliability to date. K98AL is runnin one here recently on his 235 and reporting good power and performance and over 17 mpg. We are both runnin these as daily drivers. I recommend getting the weber set up from Tom Langdon at Stovebolt Engine Company....good service and Tom will talk/email with you on getting it set up/running. A fine gentleman and it helps he was one of the GM engineers that set these motors up and kept em running originally. Do what he says, ye'll be successful. At $449 for the holly 390 from Jegs and additional $$$ for the manifold change needed to make it work, I'll run the weber on my six for a long time and not regret it. Even with all the jet tweaking, I'm still well under $400 for my carb install, not to mention the several hundred needed for a Clifford/other make of manifold to run the 4 bbl on. Mark me happy with the Weber. Total on my carb with adapter and air cleaner was under $280, add about $35 for various jets tried till I settled on the ones I have now and I'm still under $320....less than half of a Holly carb and useable intake manifold. + my money spent got me plenty of email and real time talk with Mr. Langdon during set up and tuning. Last edited by Sharps40; 09-02-2013 at 09:01 PM. |
#9 | |
I will Che k out your write up you did though.
Linkage was pretty easy, 98% factory. Pedal is a bit vertical but very useable.
Write up is long, its spread out over more than a few months. Been tuning all summer, making progress each time. Just about perfection now I think. |
