Coat hook location - pics?
Can someone with a factory installed coathook please post up a pic of the location of the mounted hook? I know it's somewhere forward and above the passenger seatbelt bolt on the cab pillar but I've never seen one installed so I'm not sure exactly where they go.
I have one to install in my 1970 C/10 and want to get it as close as possible. Thanks so much! Posted via Mobile Device
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
Re: Coat hook location - pics?
It is useless in the original spot so I moved mine over the right passenger area about 30 years ago.
But if no one posts a pic for you I will stick it back in the original spot and take a pic for you when I get home. Posted via Mobile Device
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
Old member
I took the coat hanger out and installed tweeters in their place. Used the same screw and hole though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Here you go that is from my 1971 GMC Sierra Grande
Hey thanks everyone for the pics. I was going to install it much lower on the pillar so I'm glad I asked!
slow-1, where did you move yours to? Over the passenger door, or to the front of the passenger compartment? Thanks again everyone! Another example of why this site is the best.
