Old 09-03-2013, 12:07 PM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Hoods!?
has anyone made a chevy hood into a GMC by swapping the front part?
if so can i get a link to it.
Sick5 is offline   Reply With Quote
Old 09-03-2013, 01:04 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Hoods!?
I have not, but I studied how it could be done....
you would need to bust all the spot welds on the seam, most are not in a spot where you could get a drill....
so I think what you would need to do is cut the gmc hood on the outside of the seam, that way you could access all the spot welds, then drill them all out , saving the gmc piece, then do just the opposite on the chevy hood, after that I think you could probably just bolt the pieces back together, rather than having to weld it...
this could be done to convert chev/gmc 62-66 hoods including the short lcf hoods., this also could be done in the same way to convert 60-61 chev/gmc hoods
Old 09-03-2013, 01:39 PM   #3
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Hoods!?
Thanks for the info
Old 09-03-2013, 10:53 PM   #4
64shortc10
64shortc10's Avatar
Re: Hoods!?
I have a clean GMC hood ill sell you for $200.00!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 09-04-2013, 12:15 PM   #5
MisterC
MisterC's Avatar
Re: Hoods!?
That IS a clean one. I've been so tempted to grab it up and make the conversion on mine. Love those GMC turn signals! Probably worth your time Gil to just buy Tony's.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 09-04-2013, 01:43 PM   #6
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Hoods!?
I'm going to check one out that the René has
