Old 09-02-2013, 10:55 PM   #1
1slo_camaro
Interior painting.... OOOPS!
Hey guys and gals I got a little annoyed with the crappy brown interior in my truck and I am slowly converting eveyrthing over to black and green on my truck everything turned out fairly well with black ( I havent added green anywhere yet) but when i took the door panel apart and painted the arm rest pad it was a week ago and will not dry. the rest of the paint looks great for a quick weekend job..... I was thinking of just soaking the arm rest in paint thinner.... would this damage the actual arm rest?
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 09-02-2013, 10:59 PM   #2
bilfman
bilfman's Avatar
Re: Interior painting.... OOOPS!
Don't soak it. Take a rag that is wet with thinner and wipe the paint off, this won't damage it.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 09-02-2013, 11:09 PM   #3
Tx79chevy
Tx79chevy's Avatar
What did you paint the armrests with? I painted mine with vinyl dye from the auto paint store and had no problems.
1951 Styleline Deluxe 2dr
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
1987 Cutlass Supreme (For Sale)
Tx79chevy is offline   Reply With Quote
Old 09-02-2013, 11:13 PM   #4
1slo_camaro
I dont think i prepped it correctly, and it was regular paint. I have done several interiors with plain paint and never had an issue i think there was still grease or oils on it and thats why it didnt dry.... i will try just wiping it down with thinner and see if i can getit cleaned up and re-do it. It sucks to... I will get pics up later but the restof the doors turned out real good but not that lol
Old 09-02-2013, 11:17 PM   #5
bilfman
bilfman's Avatar
Dupli-color sells a "for Vinyl" spray bomb in various colors. Look for some of that. It is sold at most any supplier of dupli-color.
Old 09-03-2013, 02:31 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
The duplicolor stuff in my truck didn't impress me much. It's flaking off the wear areas on my door panels and doing decent on the kick panels but I knew better than to try the arm rests.
I'm interested in seeing how the sem brand dye lasts. Considering that its more of a dye than a layer of paint
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-03-2013, 05:41 PM   #7
dieseldawg142
dieseldawg142's Avatar
i'll let you know, just today did one of the rear door panels & armrests in my crew with SEM. i'm going to give it a few days & see if it holds up to my 8 yr old before i hit the rest. goes on nice, stinks like a mother.
they used to be tan, just wondering if it will work on the map pockets, or if i'll have to order some black ones
Size:  43.7 KB Name:  018.jpg
dieseldawg142 is offline   Reply With Quote
Old 09-03-2013, 09:46 PM   #8
chengny
chengny's Avatar
It doesn't matter whether you use SEM or Duplicolor as the final trim coat - I get similar results with either.
What does matter is the prep process. It is time consuming and tedious. But without proper preparation, the surfaces to be coated will not accept the finish coat.
Anything on the substrate HAS to be removed, leaving only the raw vinyl. Use acetone or MEK. MEK is better, but is getting harder to find - many places only sell MEK Substitute now (take acetone over the MEK sub if that is the choice).
Using the solvent and a stiff scrubbing brush (not steel wires - only with nylon bristles), be meticulous and get everything off.
Many interior parts have a grained surface and these areas can be especially difficult to clean completely. The grime in the deepest parts of the grained surface will eventually come out but can be a real struggle. It helps if you continuously change the direction of the scrubbing motion. Also the bristles of the scrubbing brush may be too thick to reach down into the grooves. It this is the case, you may have to get one with finer bristles. In extreme cases, you might even have to use a brass wire brush - use it gently and try to follow the grain of the pattern.
When you have the substrate completely stripped, wash all surfaces thoroughly with warm soapy water. Rinse well and let dry. When all dry give a final wipe down with acetone/MEK.
Plastic Adhesion Promoter:
This step is vital and cannot be omitted. Again, the SEM and Duplicolor products perform equally well if properly applied:
To ensure a bond between the substrate and finish coat the plastic substrate must be "softened up" to a certain degree. There is no paint made that will adhere to the ABS plastics used to manufacture automotive panels.
This is where the adhesion promoter comes in. When applied, it temporarily breaks down the surface of the plastic and melds into it. Consequently it creates a new, uncured surface that will accept the trim paint.
There is only a very small window of time (maybe 20 mins) during which the adhesion promoter has had time to integrate itself with the plastic substrate (on the lower surface) - and yet remains wet enough (on the outer surface) to accept the final color.
After the cleaning process is complete, gather all the materials needed to prep and paint the plastic. Have them close by. You will have only 1/2 hour to get both steps done.
When the adhesion promoter has "flashed off" but is still slightly tacky, apply the trim paint. As always use long sweeping motions. Keep the can in the vertical position only with the nozzle approximately 12 inches from the work. Warm the paint in a hot water bath before application starts. This will help atomize the paint (producing a finer mist that lays down more evenly) and also helps maintain a consistent spray pattern.
Apply two light coats and a final medium wet coat. A couple of minutes dry time between each application is sufficient.
If the job is done as described above, you can expect a paint finish that closely approximates a factory look.
One word of warning: Before starting, consider the physical condition of the plastic substrate. Is it cracked? Is it crumbling and pitted from exposure to the sun? Has the surface texture of certain areas changed over the years so that they no longer match their surroundings? This happens frequently on the upper surface of door panels for example. Years of driving around with the window down and your arm resting on the plastic will wear it to a smooth surface that no longer looks like the rest of the door.
Even the most meticulous prep work, use of the best paints and perfect application techniques will not make a physically damaged plastic panel look anything like new.
chengny is offline   Reply With Quote
