Old 09-03-2013, 07:29 PM   #226
El Campo
El Campo's Avatar
Re: Attempt/Mistake #2
Even with the excessive measuring still had to do some trimming up with the panel to get it to fit perfect. Since will not be able to sandblast in this area I sprayed some of Eastwood's Inside Frame Coating into the holes provided. Ironic that it is almost exact color as original paint. A lot of the back window flange was crooked and/or bent so used this nifty pliers to straighten it out.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-03-2013, 07:33 PM   #227
El Campo
El Campo's Avatar
And its in! Its straight also which was something I was really worried about. Not welded yet as I was out of 0.23 wire but will do it this weekend. (Fitting for my 1,000th post)
Hook em Horns!!!
Old 09-03-2013, 08:34 PM   #228
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Nice work on the cab walkthrough repair so far! Keep it up!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 09-04-2013, 03:26 PM   #229
knomadd
knomadd's Avatar
Wow, that's some good fitment you've got with that panel. Your excessive measuring paid off. Good job!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 09-05-2013, 08:35 AM   #230
El Campo
El Campo's Avatar
Anyone know if this was a factory option on the camper style trucks or were there any even made with that final goal in mind? It appears to be some sort of courtesy light that fit perfectly into the gas filler hole. Also does anyone want this? Haha
Hook em Horns!!!
Old 09-05-2013, 08:36 AM   #231
El Campo
El Campo's Avatar
Edited because of Steve Job's oversight..
Hook em Horns!!!
Old 09-05-2013, 08:53 AM   #232
El Campo
El Campo's Avatar
Trying to get picture right direction...
Hook em Horns!!!
Old 09-05-2013, 09:50 AM   #233
Xeen
Xeen's Avatar
Nice job on the cab repair.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-05-2013, 11:16 AM   #234
El Campo
El Campo's Avatar
Thanks for looking guys. I'm worried about being too long winded and not having enough to show so if I don't post as often as some that is why.
Hook em Horns!!!
Old 09-05-2013, 11:17 AM   #235
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the cab splicing.
Old 09-05-2013, 08:12 PM   #236
litew8
litew8's Avatar
Nice clean work on that back panel!
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 09-07-2013, 12:20 PM   #237
El Campo
El Campo's Avatar
Every once in a while we all get lucky. Yesterday I walked into the hospital where I have worked for the last 4 years and my manager informed us all that payroll has been underpaying us on our overtime for years. So they are back paying us for all of that time. Needless to say I was blessed enough to get quite a chunk of money so will be buying everything I need to finish frame and drivetrain plus other stuff too. This includes all new Moog tie rods, ball joints, pitman arm, rebuild kit for my steering gear, Ratech (American made) 12 bolt rearend rebuild kit, and Dutchman axles. Will also be buying a new roof skin (if I cannot find an OEM one which I have not had any luck with yet), some more epoxy primer and then everything I need from Sound Deadener Showdown (going to use science to deaden noise instead of just layers and layers of Dynamat ) to insulate and deaden the roof noise. Have to do a class for work today so will not be able to work on back panel of cab until tomorrow
Hook em Horns!!!
Old 09-07-2013, 02:48 PM   #238
Xeen
Xeen's Avatar
I normally wouldn't presume to interject myself in someone elses business however, take it from someone who had nearly the exact same thing happen to them, prioritize well because I blew about 13 grand in the blink of an eye and then looked at my truck and thought to myself "I didn't plan very well" I bought stuff I didn't need to get it back on the road running and driving like luxury items that I probably wouldn't have bought if I wasn't flush with cash.
I had a tendancy to think "ok so it's $500 I got money so heck yeah I'm gonna get it" well when you buy a whole bunch of parts that are $500 or more apiece it adds up insanely fast
My advice is to concentrate on the parts you need to get it running and driving again then once that is done buy all the toys for it you want.
Old 09-07-2013, 04:52 PM   #239
El Campo
El Campo's Avatar
I would agree with you except I have already been down that road and never again will I do something if I can't do it the right way the first time. Having already built this truck once and having had it run and drive and haul all kinds of a$$ and yet not being exactly what I wanted taught me a lot. Thank goodness that I am more comfortable than I used to be and having plenty of other transportation options so if it takes me 5 more years to build this it doesn't phase me. I would rather have it be exactly what I wanted than have it finished and be subpar. Everything I am planning on buying was on the "to buy list" anyways. I won't buy anything that wasn't already planned on. I appreciate the concern for my project though! Seriously.
Hook em Horns!!!
Old 09-08-2013, 01:24 PM   #240
El Campo
El Campo's Avatar
Since I finally figured out how to upload from iPhone I will be doing real time updates today. In the process of scalping the green cab. Wire wheeling the original seam sealer out of drip rails:
Hook em Horns!!!
Old 09-08-2013, 01:26 PM   #241
El Campo
El Campo's Avatar
Proof that rust on cab is surface rust and not heartbreaking structural rust
Hook em Horns!!!
Old 09-08-2013, 02:00 PM   #242
Xeen
Xeen's Avatar
That looks like a good candidate for a fiberglass backed Polycarbide disk.
Slap it on your side angle grinder and go to town, it will remove all that rust on contact and you dont even have to apply pressure just the weight of the angle grinder will do the job in most cases and it will resurface the metal to a near factory condition, you may even decide you don't need to replace the roof skin once you see how nice it looks.
http://www.harborfreight.com/4-1-2-h...eel-94017.html
Old 09-08-2013, 02:21 PM   #243
El Campo
El Campo's Avatar
Good idea. Ill def try that on the other rust on the cab! Main reason I'm removing existing roof is because of the cab lights that sit on raised pedestals. I love Amazon btw, from advice gleaned here and on other forums I purchased these spot weld cutters from Blair. Only 35 dollars from amazon unlike the 100 charged locally.
Hook em Horns!!!
Old 09-08-2013, 02:24 PM   #244
El Campo
El Campo's Avatar
These look like they should be far superior to the Harbor Freight "hole saw" style cutter that I had before. And of course, you cannot beat American made
Hook em Horns!!!
Old 09-08-2013, 03:04 PM   #245
Xeen
Xeen's Avatar
In the area of the roof marker lights there aren't any complicated compound curves.
It won't hurt anything to try and cut out the entire raised surface and just patch it, who knows you may find you can make it look really good and you can save the money that the roof skin costs for something else you want.
You got nothing to lose man give it a shot.
Old 09-08-2013, 08:16 PM   #246
El Campo
El Campo's Avatar
Good point but my body working skills aren't up to that job . I don't have the necessary talent to do that unfortunately. Here's spot weld cutting action.
Hook em Horns!!!
Old 09-08-2013, 08:29 PM   #247
Xeen
Xeen's Avatar
Chances are the reproduction roof skin will require some pie cutting and welding to make it fit the rear seam so you arent getting out of welding no matter which way you go
Old 09-08-2013, 09:41 PM   #248
knomadd
knomadd's Avatar
Since you're already cutting it off, you can bring the roof skin my way and I can try to cut and patch it for you. It's been a few years since I've done a lot of bodywork, but I've done that kind of thing before. I don't want to promise that I can get it where you want it without some filler, but if you're willing to let me try, I might be able to save you some money and time trying to make a reproduction piece work. Or, I could come down your way sometime. I'm always willing to lend a hand, as long as my schedule and wife will allow it.
-Duane
Old 09-08-2013, 10:46 PM   #249
El Campo
El Campo's Avatar
I sure appreciate it knomadd! I will see if I can find an original or not and go from there. Well, I didn't get as far as I had hoped because my small air compressor crapped out on me and I had never known how to wire the big compressor I purchased about 7 months ago. The other night my younger brother had a bunch of his friends over and it just so happened that one of them is the son of a very well known electrician here and is a journeyman himself so I picked his brain how to wire the motor. He told me how but it still took me several hours to get all wire and other paraphernalia around to complete it. It runs though finally so all I need is a few fittings and I will have lots of air tomorrow!
Hook em Horns!!!
Old 09-08-2013, 10:56 PM   #250
El Campo
El Campo's Avatar
Hook em Horns!!!
