09-03-2013, 01:29 PM | #1 |
th350 to th400 with 70 factory tilt whell question
I have a 1970 cst with factory tilt wheel that am going to be chaging the th350 to a th 400. My question is if I use an original th400 from 70 truck with all related truck shift linkage, replace the indicator on the column as for a th400 will the indicator line up correctly and the column have the extra travel for the extra gear. Is the tilt column unique to the th350 and the th400?
09-03-2013, 01:32 PM | #2 |
Re: th350 to th400 with 70 factory tilt whell question
Knowing GM, the column is the same.
BTW, TH350 and TH400 are both 3 speed transmissions
09-03-2013, 01:36 PM | #3 |
Da my bad I was having a senior moment, yes of course they are both 3 speeds so nothing would need to be changed on the column and the indicator will match what gear I am in correctly?
09-03-2013, 01:53 PM | #4 |
Moderator
Yes, correct. The linkage is slightly different however
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-03-2013, 02:26 PM | #5 |
you need a different driveshaft
09-03-2013, 07:50 PM | #6 |
The indicator will line up correctly as long as the shift linkage is adjusted properly after you get the new trans in, it is sometimes over looked so just thought I'd throw that out there.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
