Closed Thread
Old 09-02-2013, 11:49 PM   #7826
PAWS 72
PAWS 72's Avatar
Re: What did you do to your truck today!
Guys quit showing off such nice bikes. I lovem.
Got in the truck this morning going to a car show and the alternator went out. So you know what kinda day I had. BYW,I did get the later model alt. and put it on so the upgrade on that is done. now for the headlights.
PAWS 72 is offline
Old 09-02-2013, 11:50 PM   #7827
PAWS 72
PAWS 72's Avatar
Originally Posted by hopped up View Post
Those are some very nice bikes! Got any more pix? Do you ride them or are they too nice to ride? What other bikes you got?
Nice looking truck and bikes.
PAWS 72 is offline
Old 09-03-2013, 12:13 AM   #7828
mud.man.rj
mud.man.rj's Avatar
speaking of headlights, just came back from a 700 plus mile road trip and my truck is so high I couldn't see the road due to normal halogens in it so just upgraded to HID headlights today, wow what a difference, can't wait for the next roadtrip...have to save for gas first.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 09-03-2013, 02:56 PM   #7829
vegadesign
vegadesign's Avatar
Broke it again.....
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline
Old 09-03-2013, 08:27 PM   #7830
mud.man.rj
mud.man.rj's Avatar
The hanger bearing design sucks though, see you even had some extra welded to the sides.
5.0 4spd std.
7" lift w 35's.
Old 09-03-2013, 10:00 PM   #7831
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Changed the oil and filter.
Had some "soft" in the brake pedal. No one else around. So, I started at the rear passengers side drum and cracked the bleeder (after I made sure the m/c was full).
Took about 20 seconds and then out came some brake fluid. Repeat on the driver's rear drum. Maybe 10 seconds this time and I got some gravity-fed juice. The two
front calipers only took less than five seconds each until I got some.
Brake pedal was "hard" on the test drive...Great!!!! I was surprised. I'll have to do it again when I have help. But that was good for a solo-run.
When I pulled back into the house after the test, the LMC gap cover (covering the space between the grille and radiator core) was sitting in a box at the front gate.
I put it on. Easy fit. I kinda wish it was made out of heavier stock. They advertised, "polished aluminum"...I guess it *is* aluminum. But I couldn't really tell it
from shiny sheet metal.
I like it, though.
A good day.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 09-03-2013, 10:05 PM   #7832
In The Ten Ring
I finally decided what I would do and dropped the carb and rebuild kit off at a garage for the job.
In The Ten Ring is offline
Old 09-03-2013, 10:15 PM   #7833
vegadesign
vegadesign's Avatar
Yea u welded in some flatbar to reinforce the sizes and apparently was too much so the bolts tore out
Old 09-03-2013, 10:48 PM   #7834
slow-1
slow-1's Avatar
Originally Posted by vegadesign View Post
Broke it again.....
Dang...how does that happen?
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline
Old 09-03-2013, 10:53 PM   #7835
rincones
rincones's Avatar
Painted some of the parts two weeks ago.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Rincon
rincones is offline
Old 09-03-2013, 10:55 PM   #7836
Towstrap
Towstrap's Avatar
its getting there should have color on her this week
Towstrap is offline
Old 09-03-2013, 11:01 PM   #7837
mmiddle
mmiddle's Avatar
HorsePower! I guess.... I used to break them all the time in my 69. That is until I made one out of heavy steel and urathan bushing. That is the only way I know, it is just a crappy design.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline
Old 09-03-2013, 11:35 PM   #7838
SCHRUMGMC
SCHRUMGMC's Avatar
What type of What fiber spark plug does I 1971 GMC Sierra take
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 09-04-2013, 05:35 PM   #7839
magwakeenercew2jh
Another bit of fun in the garage today. Had some left-over carpet. The chunk from my failed attempt at creating a home-grown headliner.
So I cut *it* up to make some kick panels for below the door panels.
Cleaned up the elec. window wiring. Tightened a cab mount and called it a day.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-04-2013, 06:11 PM   #7840
Lee H
Lee H's Avatar
This is usually caused by improper drive line angles and or unbalanced drive shaft. This is very common when a truck is lowered and the drive line angles are not corrected. This is very uncommon on a truck with stock suspension.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline
Old 09-04-2013, 07:29 PM   #7841
mud.man.rj
mud.man.rj's Avatar
It is common with a lot of HP though, torque is hard on them.
5.0 4spd std.
7" lift w 35's.
Old 09-04-2013, 07:30 PM   #7842
SCHRUMGMC
SCHRUMGMC's Avatar
Bought a Coil and some new spark plugs
1971 GMC Sierra
1959 GMC 100
Old 09-04-2013, 08:42 PM   #7843
flashed
Waited for the muffler shop to call and say its ready ,never got the call so it must be being a pain ,had a few broken bolts in the exhaust manifold (6 cyl 74 Chevy) ,but all is good ,need to drive the El Camino some anyway.
flashed is offline
Old 09-04-2013, 09:07 PM   #7844
lil hoodlum
lil hoodlum's Avatar
I changed the oil and oil filter. It has been over a year and a half since I last changed the oil. I have put on over 10,000 miles highway on the old 350 with in the last year alone.
Went through a devastating break-up over a year ago that really took me down. Just now really putting my life back together.
Keith
lil hoodlum is offline
Old 09-04-2013, 09:18 PM   #7845
rob32472
Took her to the alignment shop....
rob32472 is offline
Old 09-04-2013, 09:45 PM   #7846
Avitech
Avitech's Avatar
Got the windshield and seal replaced.
received a Christmas package from LMC Truck
- Headlight harness
- new dome light w/ clear lens and LED bulb
- Black round head mirrors
- new T-case boot
bought tint for the back glass, gear oil for the differentials as well.
Tomorrow will be busy!
1990 Suburban Silverado
350, SM465 and 35" tires
Avitech is offline
Old 09-04-2013, 10:20 PM   #7847
SCHRUMGMC
SCHRUMGMC's Avatar
Took off the Towing Mirrors I am looking for the Tripod Towing mirrors and can't seem too find any ?
1971 GMC Sierra
1959 GMC 100
Old 09-04-2013, 10:23 PM   #7848
magwakeenercew2jh
Originally Posted by lil hoodlum View Post
....snip... Just now really putting my life back together.
Keith
Good for you. Trucks help that stuff.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-05-2013, 02:32 AM   #7849
draggin49
No physical labor, just ran up the debit card lol. New tires for the new wheels and new chrome bumpers from brothers. Wheels/bumpers should go well together.my truck came with mismatched bumpers anyways.
Also have an ece 4.5/6 thats goin on soon along with power disc brakes and a 350 with a 700r4
The paint/interior are whats left from the assembly line all that im gonna leave, gives the truck some character
The maiden voyage is getting closer!!!!
draggin49 is offline
Old 09-05-2013, 10:24 AM   #7850
tommys72
tommys72's Avatar
Originally Posted by 72Souper View Post
My dad and i watched a window installation video (i have a truck with stainless trim), looked pretty "easy". Then i read a lot of experiences on this board. Decided it was anything but "easy". We took it to an autoglass shop and it took them 3 tries to get it in! Best choice we made in a long time!
It took the glass guy that did mine about ten hours total and two windshields, he eventually got it in though. And the crazy thing is he's being it for about 30 years
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline
Closed Thread
