Engine blowing oil around carb onto intake
My engine is blowing oil out all over the place. It's pooling up on the intake under the breather on both sides of the carb. Any ideas what's causing this? Casting number cross references to 307 but the guy I got it from says its a 350 with a fairly recent overhaul. I'm not sure....
Posted via Mobile Device |
![]() Join Date: Aug 2008
Re: Engine blowing oil around carb onto intake
So...wheres it coming from? It might be something as simple as loose intake bolts.
Wide side: hello from just up the road a bit!!!! I wished I knew where it was coming from. I don't think it's intake bolts because there are no water leaks or apparent vacuum/air leaks because it runs ok but I will check for sure tomorrow. I hope it's something simple and not major. Could it be a major issue?????
20' Daredevil (Ret)
![]() Join Date: May 2003
Intake bolts can leak oil even if they're tight, and without air or water leaks. Some of the bolts extend into the lifter galley. Can't recall which bolts need thread sealer..... hopefully someone will jump in. Or just seal them all to be sure.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 09-03-2013 at 12:35 AM. |
My first thought was no sealant on the intake bolts, Most intakes need to be re torqued after a bit of run time.
Do you have a copper oil line running to the oil pressure gauge? make sure its not got a pin hole and spraying oil (yea i just come up with any other possible source of oil, seem pretty far fetched)
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Yes copper line, I will check that to. I'm really worried because I read some info on this when I googled it and many say it is caused by blow by due to bad piston rings, etc, any thoughts on that? Is that possible?
Forgot to mention that oil pressure is good when cold but gage bottoms out when hot at idle but jumps right back up and pegs out when u give it gas
What do you have for crankcase ventilation? Are the valve covers n& air cleaner original? Is there a tube to the filter housing from the valve cover and a PCV valve on the other side? If it has aftermarket valve covers & air cleaner,what's there for venting? If you have a PCV valve,is it clogged?
Gonna need some pics here.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Ill get some pics together later today. I will look at the crankcase ventilation as well....
I am a Referee of life.
Could also be as simple as valve cover gaskets though they usually leak on the outside.However I have seen people tighten them too much on the outter bolts and cause a leak on the intake side.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
The two center intake bolts on both sides go into the lifter valley and need sealant or they will leak.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#13 | |||
"I ain't nobody, dork."
A functioning PCV system is paramount in these old engines. Gary
Florida Edition
![]() ![]() Join Date: Oct 2010
This is common and an easy fix........
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#15 |
Those intake bolts can leak (seep),but not how the author of this thread describes.
#16 |
Not sure what's going on yet, did not get a chance to look into it today. The oil seems to pool up more on the drivers side than the passenger side. Ther reason I say it's "spraying is because there is a light film of oil on the underside of the breather and on the carb, valve cover and intake all around the carb area. Confused!!!!!
Posted via Mobile Device Last edited by Jdbfish; 09-03-2013 at 11:20 PM. |
#17 |
Posted via Mobile Deviceanother pic
#18 |
Posted via Mobile Deviceand one more
Posted via Mobile Device Posted via Mobile Device |
#19 |
You absolutely certain it is oil, and not coolant that has mixed with grime to become that color?
