Old 09-03-2013, 09:11 PM   #1
Tx79chevy
Tx79chevy's Avatar
75 won't start
I will start off by saying that my mechanical knowledge is limited so please bear with me. I got in my 75 today and it cranked like usual but only ran for about a second then died and wouldnt crank back up. I figured maybe the fuel pump went out but it's working fine. Checked the spark at the plugs and it's getting spark. The engine turns over just as strong as ever. So the starter is fine and it's getting fuel and spark, so now I have no idea. It has the stock 350 in it. Any help would be greatly appreciated.
1951 Styleline Deluxe 2dr
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
1987 Cutlass Supreme (For Sale)
Tx79chevy is offline   Reply With Quote
Old 09-03-2013, 09:21 PM   #2
07XCSBZ71
07XCSBZ71's Avatar
Re: 75 won't start
Pour a little gas in the carb and try it. Could be a clogged carb filter.
07XCSBZ71 is offline   Reply With Quote
Old 09-03-2013, 10:27 PM   #3
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
Could it still be a clogged carb filter even if I can see gas squirting into the carb?
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-03-2013, 10:34 PM   #4
geezer#99
geezer#99's Avatar
Re: 75 won't start
If you got accelerator pump spraying then you got gas. Maybe too much gas. Hold the pedal to the floor and crank it till it starts. Might be crap in the needle/seat making it flood a bit.
Old 09-03-2013, 10:49 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 75 won't start
or a leaky/broken main gas line
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 09-03-2013, 10:49 PM   #6
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
Ok just went and held the pedal to the floor and still nothing.
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-03-2013, 11:29 PM   #7
geezer#99
geezer#99's Avatar
Re: 75 won't start
Not even a sputter?
How long did you hold the pedal to the floor?
Old 09-03-2013, 11:38 PM   #8
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
Yeah not even a sputter. I held it for a good 15-20 seconds. Multiple times.
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-03-2013, 11:48 PM   #9
geezer#99
geezer#99's Avatar
Re: 75 won't start
Maybe the distributor is loose and the timing has retarded a bit.
Can you grab the vacuum pot and move the distributor easily?
Old 09-04-2013, 12:01 AM   #10
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
I honestly don't know what a vacuum pot is. I know when it turns over, it turns over just as fast and strong as it always has.
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-04-2013, 12:10 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 75 won't start
dry out a water bottle
poke a hole in the lid
fill bottle with gas
squirt some into carb
try and start it
John
Old 09-04-2013, 12:12 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 75 won't start
vac pot is the grey thing sticking out of the side of the dizzy usally on the pass side
John
Old 09-04-2013, 12:18 AM   #13
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
I will put gas directly into the carb tomorrow. Maybe that will change something. I will post the results.
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-04-2013, 09:09 AM   #14
geezer#99
geezer#99's Avatar
Re: 75 won't start
If you stroke the throttle 2 times and see fuel being sprayed inside then don't waste your time making a bottle to pour more in with. You'll have more than enough to make it start.
Old 09-04-2013, 12:28 PM   #15
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
Ok yeah I didn't try pouring gas in it yet but gas is definitely spraying in there.
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-04-2013, 12:47 PM   #16
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
Went ahead and poured gas into the carb for the hell of it and yeah still nothing.
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-04-2013, 06:38 PM   #17
SCOTI
SCOTI's Avatar
Re: 75 won't start
Neutral safety switch? Not 100% sure how they prevent the vehicle from starting but I know if not in the right position, they'll do just that.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-04-2013, 07:30 PM   #18
geezer#99
geezer#99's Avatar
Re: 75 won't start
Nuetral safety switch is wired between the ignition switch and the S terminal on the solenoid. If it cranks it's not the NSS.
Old 09-04-2013, 10:00 PM   #19
Your41Plague12
Your41Plague12's Avatar
Re: 75 won't start
My bet is timing. Definitely grab the vacuum advance and see if you can rotate the distributor.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-04-2013, 10:04 PM   #20
f.monroe
f.monroe's Avatar
Re: 75 won't start
The rotor in the distributor could be bad. It will break down under load and will not allow it to start. They are cheap and worth a try. Cap and rotor can be bought cheap but you may just try the rotor first.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 09-04-2013, 11:35 PM   #21
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
I'm goin to check the rotor tomorrow. Maybe I will get luck and that will be it.
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-05-2013, 06:43 PM   #22
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
Put a new rotor in the distributor. Still nothing. I noticed a little piece of metal that fell out when I took the cap off. So maybe a new distributor cap is needed?
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-05-2013, 09:08 PM   #23
geezer#99
geezer#99's Avatar
Re: 75 won't start
Grab the vacuum advance pot and rotate the distributor about 1 inch. I'm sure it's slightly loose already.
Old 09-05-2013, 10:06 PM   #24
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
Should it just turn or will I need to loosen something?
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-05-2013, 10:27 PM   #25
geezer#99
geezer#99's Avatar
Re: 75 won't start
If it won't move easily then look under the cap down by the intake manifold. You'll see the head of a bolt that is tightened on a clamp that holds the dizzy in place. Could be 1/2 or 9/16 inch bolt. Loosen it slightly to rotate the dizzy counterclockwise. Move it about 1/2 inch to 1 inch and see if it wants to start.
If it starts then tighten the bolt again.
