Old 08-30-2013, 12:45 PM   #1
mullinax5630
Help lowering front 5 inches
I am interested in lowering the front of my 65 5 inches on the cheap.ideas please without spindles.
mullinax5630 is offline   Reply With Quote
Old 08-30-2013, 01:20 PM   #2
Clyde65
Clyde65's Avatar
Re: Help lowering front 5 inches
Nothing cheap, if your going to do it, do it right. 2.5 drop spindles and 3" drop springs. Spindles and bags, either way.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-30-2013, 01:55 PM   #3
ChevyJr
Junior Member
ChevyJr's Avatar
He's right. I'm as cheap as it gets HAHA but I went with 2.5 drop spindles and 2" drop coils...So I guess technically not 5, but pretty damn close. I'm going with air ride later
ChevyJr is offline   Reply With Quote
Old 08-30-2013, 03:14 PM   #4
shok
Whats the lowest you can go with just springs without having it ride like hell?
1966 C10 250 with 3 on the tree Build Thread
Bunch of other cars no one cares about
shok is offline   Reply With Quote
Old 08-30-2013, 03:31 PM   #5
boucher racing
boucher racing's Avatar
I cut 1 & 3/4 off the front of my 66 GMC's. I removed the rubber stops and trimmed off the perches. Looking under the truck, it is about as low as you can go on the cheap. If you do drop it that much, you will have to change out the shocks because they will bottom out, FYI.
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 08-30-2013, 04:01 PM   #6
Clyde65
Clyde65's Avatar
I know they sell 3" drop coils. I have only rode in 1 vehicle with cut coils and it wasnt very good ride. Either buy the springs, buy the spindles or just forget about it.
Clyde65
Rebuild of Clyde
support our troops!
Old 08-30-2013, 04:34 PM   #7
shok
Yeah in my case just curious on a aftermarket spring only drop, not cut. I should have been clearer.
Old 08-30-2013, 08:49 PM   #8
duallyjams
duallyjams's Avatar
Super cheap heat the springs with a torch. I wouldn't recommend it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-31-2013, 03:58 AM   #9
Vernski
X2 I don't recommend it either, if you don't have the money save it until you
can do it the right way. You will be much safer on the road and safer for others
that have to share the road with you please..Vernski
Vernski is offline   Reply With Quote
Old 09-01-2013, 12:07 AM   #10
donthekawguy
donthekawguy's Avatar
My fronts are cut and it hits hard on almost any bump. I'll be putting springs spindles and discs up front next year. I might get some shocks for now and then use them next year with the new set up. Everyone is right, save up and do it right and you won't be disappointed. Do it cheap (wrong) and you will be disappointed and dangerous.
66 shorty
donthekawguy is offline   Reply With Quote
Old 09-01-2013, 10:32 AM   #11
boucher racing
I have cut the last two C10's and it rides great. On the first truck, I too thought that I was bottoming out. via. lower control arm, but I wasn't. My shocks were. The compressed length was too short. I replaced the shocks with a shorter compressed length and voila the ride was great, no bottoming out.
Check it,
http://67-72chevytrucks.com/vboard/s...d.php?t=573266
"Cropwell" 66 C10
Old 09-01-2013, 11:14 AM   #12
chevyrestoguy
chevyrestoguy's Avatar
Just remember that if you go down 5" in the front, the lower control arm height to the ground become the bigger issue. I've had them this way, but you have to change your driving habits and be very mindful of what's ahead in the road and react accordingly. When you bash the lower control arms off of the ground at 55 mph, that gets your attention quickly. And it beats the LCAs to death.
Low=slow.......
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-03-2013, 10:23 AM   #13
mullinax5630
Thanks for the input guys thinking i may just go 4 inches instead of 5.
Old 09-03-2013, 10:26 AM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
3" drop is the max with just springs.
Keith
Convert to disc brakes.
Old 09-03-2013, 10:27 PM   #15
ol_skool_chevy
ol_skool_chevy's Avatar
I have run cut springs for over 30 years..........never once have a issue.
but use 3/4 ton springs
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 09-04-2013, 12:31 AM   #16
chopper john
chopper john's Avatar
ive cut a frw trucks and never had a problem smooth. cut two turns , removed the rubber snubber and bracket. the moved the upper shock mount up higher.
chopper john is offline   Reply With Quote
