Old 04-18-2012, 09:45 PM   #26
Mark B
Mark B's Avatar
Re: Inline Six Rebuild
Bye bye Scrapper engine.
You're too heavy to launch for a raft anchor. Too cumbersome for a coffee table. Too much in the way. Too lame compared to the professionally rebuilt engine. Too worn out.
It was a lot of fun to have extricated you from the salvaged truck, discover you run, take you apart, and try to make you healthy. You taught me a lot. Ultimately you were too far gone and I had a better candidate for resurrection.
Thanks to of all you guys who have lent a hand when I needed one.
You are now ready for the scrap metal man to pick up.
May you rust in peace.
Mark B is offline   Reply With Quote
Old 04-18-2012, 09:53 PM   #27
Mark B
Mark B's Avatar
I stopped by the rebuilder to check the progress. Man! Those guys do nice work. The engine is reassembled now and will be ready any day. All the visible bolts are new (like the 24 holding the oil pan on), so it all looks very nice. They even put larger valves in it! Vrooooom vroooom!
The Fixer
Old 04-18-2012, 10:18 PM   #28
Tinkermc
I am running a 350 with 700r but I like what you are doing so I will keep tabs on it
Tinkermc is offline   Reply With Quote
Old 04-23-2012, 05:35 PM   #29
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
Looks good! Any close up pics of the power steering pump bracket?
NTR72GMC is offline   Reply With Quote
Old 04-24-2012, 04:24 PM   #30
Mark B
Mark B's Avatar
I have no good pics of the ps bracket unless you want the uninstalled bracket itself.
Old 04-24-2012, 04:51 PM   #31
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
Bracket itself is good. I just want to get an idea of what they look like.
Old 04-24-2012, 06:36 PM   #32
DLOE65
DLOE65's Avatar
Fellow inliner!! Looking good!!
DLOE65 is offline   Reply With Quote
Old 05-05-2012, 08:46 AM   #33
stepside67
stepside67's Avatar
Engine Looks awesome...
Stepside67
2016 Silverado LTZ Crew Cab
2001 Suburban
2000 Sportside Reg Cab 4.8 (Stolen)
1967 SWB Stepside Project
stepside67 is offline   Reply With Quote
Old 05-05-2012, 10:44 AM   #34
IndyNova
IndyNova's Avatar
Looks good, Ive got a 70 I6 that I'm thinking of keeping the 6'er and putting an auto behind it, seeing your rebuild thread makes me lean that way even more!! Nice job
Skilled on principle, Union by choice
IndyNova is offline   Reply With Quote
Old 05-05-2012, 08:08 PM   #35
duallyjams
duallyjams's Avatar
Did the engine builder convert the connecting rods to full floating or leave them as a pressed pin .
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-06-2012, 02:28 AM   #36
Chiva1971
Chiva1971's Avatar
Thumbs up Re: Inline Six Rebuild
Hello everyone, this engine is very nice. I live in Argentina and in my country it is common for 67-72 Chevy trucks have been equipped with 6 in line engine of 250 cubic inches, so that engine you are rebuilding is well known. I ask you, what is the RPM regime with which the engine 250 operates? The trucks were manufactured there, with that corona and pinion ratio differential were fitted at the factory? . Moreover, anyone known relations between gears of the gearbox? . Can I be exceed in the questions, but I rebuild the transmission of a truck with an engine 250, and it is important to know these parameters. Thank you for your attention, greetings from Patagonian Argentina, South America.
Chiva1971 is offline   Reply With Quote
Old 05-06-2012, 09:30 AM   #37
custompaint870
custompaint870's Avatar
Nice looking truck! These trucks look great original or custom
Check out my 72 build
http://67-72chevytrucks.com/vboard/s...d.php?t=523099
custompaint870 is offline   Reply With Quote
Old 10-26-2012, 04:19 PM   #38
Mark B
Mark B's Avatar
I am back to work on this project after a long absence when summertime cottage and motorcycle activities took priority. And nothing like getting laid off from work last week to help with spare time.
Recent accomplishments:
Removed the bench seat to make easier access to work under the dash. Its very hard to reach the inside rear bolts!
Removed the original steering wheel. Bought a refurbed original auto column. $325 in this neck of the woods.
Removed the pedal assembly and took the clutch pedal off. Cleaned everything up and shot it with black paint.
Removed the emergency brake cable and pedal assembly. It will get cleaned and repainted too.
Bought replacement grommets and heater gaskets. The heater box is off the firewall.
Prepared the firewall to paint. I'll just use a spray can in a closely matched white. Good enough and it will be a big improvement.
Mark
Old 10-26-2012, 09:14 PM   #39
Tinkermc
glad you are back to work on your project and sorry you got laid off. I recently started driving driving a 66 for a DD and it has the 250 in it and I am going to leave it in. I am curious as to what your rebuild cost mine should have one this year
Old 11-26-2012, 07:49 PM   #40
TBONE1964
Cluster King
TBONE1964's Avatar
The Fixer
Very nice. I like the attention to detail. I am detailing an original 60,000 mile 292 in my 64. I understand that the factory color was not Chevy orange but a green color that is close to Detroit Diesel green. Great job!!
TBONE1964 is offline   Reply With Quote
Old 02-22-2013, 07:45 PM   #41
Calvin D.
Active Member
Calvin D.'s Avatar
Ive been searching for this for a long time I have a 69 GMC I6 3onTT SWB stepside, which Im planning of putting an auto TH350 in, and it runs a Singer Sewing Machine (and so my wife can drive it also) and was looking for info on this. keep doing what you do, I love them steppers......I am so subscribed to this.
and if anyone else following this and have more info, post them threads so it can be consolidated.
Calvin
69 SWB Stepside I6 3OTT
Soon to be LS1 5.7
66 Impala SS Conv. 396
71 Nova LT1
71 Camaro soon to be LQ4 6.0L
Calvin D. is offline   Reply With Quote
Old 09-04-2013, 06:40 AM   #42
Mark B
Mark B's Avatar
What is this external tube on my TH350?
What is the little metal tube coming out the side top of a TH350?
This trans is going behind the inline 6 into my truck.
thanks
Mark
Old 09-04-2013, 06:57 AM   #43
TBONE1964
Cluster King
TBONE1964's Avatar
Re: What is this external tube on my TH350?
thanks
Mark
That is a vent. Make sure it is not plugged up.
