Old 09-03-2013, 02:58 PM   #1
JonCheun
Thumbs down Plug Wire Burning on Headers
I've been trying to get my 1968 C10 to pass smog. In Nevada it's 1967 or older don't require smog. Some say to get classic plates but that limits you to only driving 5000 miles a year. Some say to just disconnect the odometer cable.
It passed fine last year so I don't know why it wouldn't today.
It's failing on the Hydrocarbons.
I found out that the plug wires on cylinder 5 and 6 are burning up on my headmann headers causing misfire which explains the high hc levels. These are the 2 pair of plug wires I have put on them. I even put heat shields over them this time and the headers still burnt through them.
I'm going to replace the 2 wires that burnt up but was wondering if there is any heavy duty heat shields that can help. If not, I will have to reroute them so that stay away from the headers.
JonCheun is offline   Reply With Quote
Old 09-03-2013, 03:11 PM   #2
egaray281
egaray281's Avatar
Re: Plug Wire Burning on Headers
http://www.oreillyauto.com/site/c/de...6+wire+shields
try these i have them on my truck and i also have headers this was the only way i stopped burning my wires!
egaray281 is offline   Reply With Quote
Old 09-03-2013, 03:24 PM   #3
MusicMan70
MusicMan70's Avatar
Yep I use those as well; gotem from EBay
http://www.ebay.com/itm/370784237343...84.m1423.l2649
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 09-03-2013, 03:28 PM   #4
cdowns
cdowns's Avatar
i too believe in those plug boots
all sparkplug wires are not created equal// i never had a heat problem with top of the line taylors
Old 09-03-2013, 10:02 PM   #5
How are they routed? I have no problems with burnt plug wires from headers and I run them up and away from the headers. No heat shields ever. I also prefer Taylor. They are the best
Old 09-04-2013, 03:10 PM   #6
JonCheun
They run from the distributor along side of the valve covers and down in between the header pipes. The issue is only on 5 and 6. those were the hardest spark plugs to change. I actually had to get those from underneath with a open end wrench. The Heddman Headers were existing so I didn't mess with them.
Old 09-04-2013, 03:11 PM   #7
JonCheun
Those were what I bought for 5 and 6. It burnt right threw them.
Before I changed these plugs and wires. number 6 had a heat shield on it. It was like a foil tape almost. It was old so I threw it out.
Old 09-04-2013, 03:12 PM   #8
JonCheun
Old 09-04-2013, 03:42 PM   #9
egaray281
egaray281's Avatar
Originally Posted by joncheun View Post
those were what i bought for 5 and 6. It burnt right threw them.
yea i have them on 5 and 6 i check every few days and well so far so good for me? Also let me add that my truck isnt a daily driver so maybe thats why i haven't burnt threw them yet?
Old 09-04-2013, 03:53 PM   #10
steelhorse
steelhorse's Avatar
They make shorty plugs to give you a little more clearance for this reason. Maybe those would help.
steelhorse is offline   Reply With Quote
Old 09-04-2013, 04:58 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have Headman Hedders on the 350 in my rig, with MSD wires and 90 degree boots. Never burned a single wire, and the MSD boots are pretty bulky.
You're not trying to use straight boots designed for manifolds are you?
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-04-2013, 05:05 PM   #12
JonCheun
The Heat shields are only two weeks old.
Old 09-04-2013, 05:09 PM   #13
JonCheun
Gary
I'm not trying to use straight boots at all. I'm using MSD wires with 90 degree boots.
Old 09-04-2013, 05:40 PM   #14
Lee H
Lee H's Avatar
How close is the boot to the header?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-04-2013, 06:58 PM   #15
JonCheun
It like 1" 1.5" but the boot isn't the issue. It's the wire a few inches before the boot.
Old 09-04-2013, 07:03 PM   #16
67swb72klb
67swb72klb's Avatar
I like routing them down and under the headers
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 09-04-2013, 08:46 PM   #17
Lee H
Lee H's Avatar
MSD wires burning up several inches from the tube? That thing is getting way to hot.
Old 09-04-2013, 10:35 PM   #18
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Yeah. I was going to suggest what I'm running. You can adjust the "play in the wires and clamp them down wherever you want.
But if they are not touching, and burn through when the wire is two inches away from the header???? Something else is rotten in Denmark.
If your timing was too advanced, or you were running waaaay lean, I'd suspect you'd have already had a bigger problem...
.....But what do I know?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 09-05-2013, 10:36 AM   #19
GASoline71
GASoline71's Avatar
You need some sort of wire loom that will allow you to bend the wires around the tubes and hold them in place. The cheap wire looms that come in the kits isn't enough.
So it's not the headers or the plug boots... it the looms that are causing the problem.
I am using some cheapies that I got from Summit. They bring all the wires together, and then run them to each plug. They work pretty decent for the price. But there are cleaner, and albeit, better options out there.
Gary
Old 09-05-2013, 11:02 AM   #20
jhwkns
Registered Cruiser
jhwkns's Avatar
Originally Posted by cdowns View Post
... I never had a heat problem with top of the line taylors
^^ What cliff said
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 09-05-2013, 12:21 PM   #21
BlackedOut67shorty
BlackedOut67shorty's Avatar
Mine are also ran under the headers with accel 300 plus. Didnt burn them after about a thousand miles but I think your header is getting way too hot if its burning through the shields
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 09-05-2013, 01:14 PM   #22
JonCheun
I don't know why these photos show up side ways.
I use wire looms that bolt to the valve covers.
The heat shield actually has some contact with the headers.
The heat shield doesn't look or feel burnt but when I remove it the wire is burnt.
I don't think my headers are getting too hot. The Engine temp is still 185-195 F.
I'm just going to have to route 5 and 6 under the headers.
Old 09-05-2013, 01:45 PM   #23
Lee H
Lee H's Avatar
I see, those are the same looms I use. You have them routed to close to the exhaust. Try to pull more wire through so they almost touch each other as they curl down and then toward the plug, see picture. With the way that top tube runs, looks like you are going to have a continuing problem. My 5 wire is 1 1/4 inch from the tube and has never burnt.
Old 09-05-2013, 01:58 PM   #24
Lee H
Lee H's Avatar
You can also bend a tighter radius in the bracket to get the wires closer to the block. I did that.
Old 09-06-2013, 12:32 AM   #25
JonCheun
How did you bend a tighter radius in it?
flat corner and a rubber mallet?
