Old 09-05-2013, 11:22 PM   #26
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
Thanks I will try that tomorrow.
1951 Styleline Deluxe 2dr
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
1987 Cutlass Supreme (For Sale)
Tx79chevy is offline   Reply With Quote
Old 09-06-2013, 01:34 AM   #27
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Re: 75 won't start
Cracked distributor cap or the ignition module has gone bad.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 09-06-2013, 08:55 AM   #28
geezer#99
geezer#99's Avatar
Re: 75 won't start
While your at it take a pic of your motor and dizzy for us!
Old 09-06-2013, 08:11 PM   #29
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
I took it to a friends house that is a mechanic, so he is gonna look at it for me. Thanks for all the info and suggestions guys. I will post on here when he figured out what exactly the problem is.
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-06-2013, 08:46 PM   #30
07XCSBZ71
07XCSBZ71's Avatar
Re: 75 won't start
Good luck with it and I hope you get it straightened out pretty fast and that it isn't anything serious.
07XCSBZ71 is offline   Reply With Quote
Old 09-07-2013, 10:19 AM   #31
SCOTI
SCOTI's Avatar
Re: 75 won't start
Did you confirm the rotor was actually turning?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-07-2013, 05:39 PM   #32
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
no i didnt
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-09-2013, 08:50 PM   #33
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 75 won't start
Put a new rotor in the distributor. Still nothing. I noticed a little piece of metal that fell out when I took the cap off. So maybe a new distributor cap is needed?
show your friend that piece,could be the issue
under the entire distributer cap is the rotor which has a thin strip of metal,it comes up to contact the bottom of the actual plastic cap of the the dizzy
looking up inside you should see a little round metal bump(contact bushing)
if it's flat it's wearing out,can still work tho
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 09-19-2013, 09:03 PM   #34
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
Update: Got my truck back today. The teeth on the gears for the timing chain had been sheared off. The original gears were still on there.
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-20-2013, 10:36 AM   #35
swissarmychainsaw
Re: 75 won't start
That's not good news.
Did something stop turning?
What's your next step? shop for a crate motor or fix this one?
I know you must be bummed outs since this is a new truck to you.
Just hand in there and you'll get it sorted out.
Get a manual and post pics and questions here.
swissarmychainsaw is offline   Reply With Quote
Old 09-20-2013, 11:55 AM   #36
SCOTI
SCOTI's Avatar
Re: 75 won't start
Original late 70's thru 80's gears were poly/nylon so teeth sheering after years of use is not unusual. Pop a new steel gear & chain on & it's back in business.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-20-2013, 12:58 PM   #37
Tx79chevy
Tx79chevy's Avatar
Re: 75 won't start
Yeah it had the original nylon gears. He put new gears and chain on it and it runs great now.
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
Old 09-20-2013, 01:09 PM   #38
SCOTI
SCOTI's Avatar
Re: 75 won't start
This is why I asked if the rotor was actually turning. Broken timing gear or chain = cam not turning = distributor/rotor not turning.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-20-2013, 03:31 PM   #39
swissarmychainsaw
Re: 75 won't start
Awesome dude! Congrats.
You need to post some pics!
